Question about Gateway FPD2275W LCD Monitor
Resolution Hi, I bought new monitor, set resolution in control panel to 1680X1050 as recommended. Clicked "Apply" and "OK". Works OK until I switch off. When rebooted reverts to smaller resolution with huge display and blurred photos. Running Windows XP. What am I doing wrong? Cheers,Ivor
  • ivorbigun Dec 04, 2007
    Monitor is HP W2007v, A 20 inch model. Recomended resolution is 1680x1050. Smaller resolution gives blurred phots and lettering etc.
  • ivorbigun Dec 07, 2007
    Thanks, but you missed the point. 1680x1050 is perfect but will not stay at that when rebooted. It automatically reverts to a smaller blurred resolution even though I have pressed "Apply" and "OK" to the correct resolution.
  • 270 Answers
Use 1280 x .. range resolutions for 17" monitors and 800x ... range resolutions for 15' monitors . dont hear to recommended resolutions
Posted on Dec 04, 2007
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
How do I set the resolution, screen posts a box saying for best results use 1680 x 1050@60HZ, how can I set this?
In XP goto the control panel and click display. Select the Settings tab and move the screen resolution bar to the right until it says 1680x1050.
Vista should be similar to the XP instructions.
In windows 7 goto the control panel and click display. Select Adjust Resolution from the menu to the left. Now adjust the display setting to 1680x1050.
Regards, Chris
May 13, 2011 | Philips 220SW9FB 22 inch LCD Monitor
I cannot get good resolution in my Hannspree HF229H, what can I do???
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
May 02, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
The graphics are not normal,they are big.
First try changing the display resolution by going to display properties in control panel. Move the slider to the right. Hit apply.
If this doesn't help you out, it could be a display graphics driver problem. Try going to the support website for the laptop manufacturer and download the drivers for the display adapters.
Dec 08, 2010 | Computers & Internet
If i try to connect to 1680x1050, my screen goes dark. but when im using 1600x1000 it still desplays
The resolution 1680X1050 is the native resolution for your monitor. This means that the best view for your monitor is for this resolution. Your problem in not at the resolution, it's at the refresh rate. How to fix this? Go to the settings for your screen. At the lower right corner you will locate "for advanced users" button. Click on it and choose the "screen" tab. At the lower part of the window you will locate the "refresh rate". Click on it and change it at the lower setting (about 60 - 70 Hertz). Click on aplly - OK. You will be back to the resolution settings page. Set the resolution at 1680X1050, apply - ok. Go back to "refresh rate" window and change the setting to a higher setting STEP BY STEP. In case of an "out of range" and blaack screen DON'T DO ANYTHING, at 15 seconds you will come back to the previous settings. With this procedure you will get the native resolution for your screen with the higher refresh rate.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 07, 2010 | Samsung 226BW Monitor
If connected to a 64 bit Dell Studio, it is difficult to view monitor. can you help? It works perfectly on a HP pavilion, but not the dell
Your resolution is probably not set correctly. That monitor can only support a resolution of 1024x768 - so to change that, you'll need to go into Start - Control Panel - Display Settings, and then click on the settings tab, and near the bottom where it says "display resolution" drag the slider until it says 1024x768. Press apply or ok and see if that helps.
Jan 20, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
I had to reinstall my Viewsonic monitor after getting a new hard drive. Now the screen shows everything is a horizontal stretched mode. How do I get it to normal aspect ratio?
It seems like the display resolution was not set to the optimal resolution for your monitor.
To correct this, follow this guide. I am assuming you have Windows XP.
1) Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
2) In the Control Panel window, open Display.
In Microsoft Windows XP, depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
3) In the Display Properties window, click on the Settings tab.
4) Slide the Screen resolution slider all the way to the right for your optimal resolution.
5) Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
NOTE: If the text appears too small, go back to step 4 and try a different position on the slider until you get it how you like it.
Good luck on solving your computer problem.
Aug 27, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
How do I get the resolution to be the recommend 1680x1050
more powerful video card. a video card with higher resolution.
Aug 20, 2009 | HP L2245w 22 inch Monitor
Cannot set screen to max (1920x1200) resolution
When changing the resolution click "apply" and then "OK" in the properties menu. That should help it stick! FIXYA!
Apr 28, 2009 | Computers & Internet
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway FPD2275W LCD Monitor Logo
247 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
