Question about Samsung SF-340 Plain Paper Inkjet Fax
How do i add a name/number to the phonebook memory?
  • anabelen Aug 08, 2008
    How do I add a name/number to the phonebook memory?
    Your answer is not appropiate so it's possible you get the instructions for SF-340 from you work?
Have samsung sf 40 fax how do you operate
Posted on Apr 01, 2008
  • 417 Answers
I think that do the following and if it doesn't work let me know and I will be able to obtain a manual from work and give you detailed instructions.
Press Menu
Move to register quick dial
press enter/select/start
then register
Follow the on screen instruction.
When you come to enter the name of your contact use the number pad as you would when SMS text on your mobile phone.
Thanks J
Posted on Jan 06, 2008
Cant type name into phonebook,it will only type numbers
No you can't lose all that you have in memory, but that is not the solution to your problem.try to dail the number you want to store or save on your phone then stop the dailing the number click on the number you dail again and go to option when you click on option it will bring some list for you click on save then type the name and save the number is there already.
Dec 20, 2011 | Panasonic KXTG7230EM Phone
It can shown contact memory 16% use 326 contact but in name list no contact seen? what i do?
go to phonebook, phonebook settings, show numbers on phone, memory, or sim. choose phone memory if your contacts are saved in your phone memory.
Mar 28, 2011 | Nokia 3110 Cellular Phone
Special code of motorola nextel i836
hi,
Here are the codes
1) to find out the IMEI number:*#06#
2) this is used to lock keys Press together *7
[] (pause) means the * key held in until box appears.
3)Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
4)Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
5)Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
6)Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
7)Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
8)Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
9)Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
10)Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
11)Enable EFR:
[] [] [] 1 1 9 [] 1 []
12)Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
thank you for using fixya.have a nice day :-)
Jul 24, 2010 | Motorola Mobility i836 Cellular Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
Nokia 7310 Supernova. If someone calls cant see their name!
well, simple problem in your device.
You must have copied each number with two names or there may be double entery inside phone.
possibly problems
  • Double entry for single number
  • same contact in phone and sim
  • missing country code (ex. +91 xxx) in special cases
Solution:
  • take one other phone, and delete that number from your phone (sim n phone both memory) after deleting that contact details, misscall from working phone to your phone, and store that contact in ur phonebook
  • delete all contacts and add one time only. make sure no double copying
  • add country code before number
Tht's it, solution is as simple as 1 2 3
www.softzonelab.com
Jul 08, 2009 | Nokia 7310 Cellular Phone
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
Cant access phonebook
your on the right track 1# then scroll through to find the number without the name and either delete it or add a name to it
Nov 07, 2006 | Motorola Mobility V300
Samsung SF-340 Plain Paper Inkjet Fax Logo
153 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
