Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Dianostic indicates need for a new battery
Where is battery located to replace
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Service indicator sign
U NEED IT TO HAVE DIANOSTIC TEST
Oct 09, 2015 | Cars & Trucks
Car wont start unless i jump start it had checked by halfords said battery starter and altenator all fine then had it put on dianostic machine said no faults was told battery needed replaced put new...
If you can check battery make sure it's reading 12v if so your starter is probably going bad that's why you have to double the voltage almost to make it turn over
Feb 02, 2015 | Cars & Trucks
Where is the body control module located on a 2007 nissan armada
Along the steering column near the dianostic link connector. lower of the instrument panel
Feb 26, 2012 | Cars & Trucks
Dymo letra tag print is unreadable
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
May 17, 2011 | Office Equipment & Supplies
Engine light has turned on, computer dianostic indicates knock sensor. Knock sensor replaced by chevrolet dealer on april of 2010.
I recently had the same problem but with a different make and model vehicle. I replaced the Cam Shaft Sensor and that took care of the problem. Contact the dealer i'm sure it should still be under warranty, also they have the necessary tools to check if the sensor is sending the right pulses while running. Good Luck.
Sep 04, 2010 | Chevrolet Silverado 1500 Cars & Trucks
I had asked about the check oil light coming on and going off on my 2004 buick lesabre, the person mentioned a sensor in the oil pan. Can this be checked out by finding a dianostic code or does the oil pan...
I know nothing of a sensor in the oil pan. What you need to check is the oil pressure sending unit. The unit will look like this. 2c49e3a.png
Check the connection at the sensor to make sure it is secure before replacing. If you find it is leaking it for sure needs replacing. The unit will be located in a location like this on which is a 1995 Buick. 2a08cb5.png
Jul 24, 2010 | 2004 Buick LeSabre
The cig lighter stopped working, I use it to run the GPS
Check the lighter fuse, it is usually on it's own circuit and your owners manual should show which fuse it is. The adapter may also be bad for the GPS, see if the lighter will function and get hot.
Feb 27, 2010 | 2003 Nissan Altima
2002 chrysler town and country wont leave limp mode
try getting a new shift solenoid for it. i had the same problem on my 2002 chrysler town and country and my plymouth breeze which is also a dodge product. it is very simple to do and doesnt take all that long. the part will probably run you about 150 to 200 dollars but it should fix your problem.
Dec 31, 2008 | 2002 Chrysler Town & Country
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
99 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
