Question about Gateway 2520915 Keyboard
Keyboard to Laptop connectors
I have a Gateway Keyboard which I would like to connect to a Gateway Labtop. Is there an adapter available which would make this possible (6 pin to USB)? Where would I purchase one if there is one on the market?
Go to Amazon.com, and look up ps/2 (which is the official name for the connector type normal keyboards have) to usb adapter, and you should find a little green thing that adapts your keyboard to usb. Make sure that the usb is a male end, and the ps/2 is a female end, or you've got the wrong one.
However, before you do that, I want to let you know that I just did the same thing, and I cannot get my Gateway keyboard to work on my HP laptop through usb. I have no idea why, and I am currently trying to find a solution. So I wouldn't suggest buying it until you know how to fix it. If you figure it out let me know.
Posted on Apr 11, 2008
Remove top
To me when you state remove the top of a laptop, you are talking about removing the Palm Rest Cover.
With the laptop closed, the top cover is the Display Cover.
This, I suppose, could be considered the 'Top' also.
At any Ol' rate here is the link to a free Service Manual, for the Gateway NV53 series of Notebook PC's.
I think you'll find it crosses directly over, to the Gateway NV52 series of Notebook PC's; which you have one of,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Go to the top line - Gateway 400. (400 in blue)
Drop down to the second line, scroll over, and click on the blue -
NV53
Now you can disassemble the Display Assembly, or remove the Palm Rest Cover.
If it is the Palm Rest Cover post back in a Comment.
The reason is I want to give you needed information.
The main one is the Keyboard Cable connector on the motherboard.
IF you break that ZIF connector, you are looking at MOTHERBOARD REPLACEMENT, and why I want to guide you.
(Or any of the other ZIF connectors on the motherboard.
Zero Insertion Force)
A) http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Gateway NV52L06u Laptop PC
Keyboard doesn't work
To determine if the motherboard is faulty, connect an USB keyboard to your laptop an see if the keyboard works properly. If so then the laptop keyboard may only need the keyboard connector unplugged and then plugged back onto the motherboard.
Nov 29, 2012 | Gateway NE56R10u Laptop
Replace a keyboard
Most laptop keyboard are secured by screws on the bottom of the laptop. The screws that fix the keyboard may have a tiny heyboard symbol against the screw.
When you remove the keyboard screws you can then lift the keyboard off the laptop. The keyboard is connected to the motherboard via a flat ribbon cable, it may have a connector on the cable or a locking clip on the motherboard. Release this ribbom cable from the motherboard, don't pull on this cable or you may damage the ribbon cable.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment are available from this WEB site.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards.
Mar 02, 2012 | Gateway NV7802U Notebook
How to remove touchpad for cleaning gateway ID58 notebook Windows 7 i have all screws off back, removed battery and hard drive, silver strips on side seem to be the next step
Power off the Gateway laptop, then disconnect the AC adapter from the power jack. Remove any other devices connected to the laptop.
Place your hand on a bare metal surface to release any buildup of static electricity. Close the lid to your laptop and turn the computer over.
Slide the battery lock over to the side to pop the battery out from its compartment.
Set the battery aside, then turn your computer over once again so that it's facing up. Rotate the laptop so that the back (not the bottom) is facing you.
5
Remove the two screws securing the bezel in place from the back of the laptop.
6
Open the lid to the laptop, then insert a flat-head screwdriver underneath one end of the bezel to loosen it from the top cover. The bezel is located just above the keyboard, but below the monitor.
7
Carefully remove the bezel the rest of the way. Insert the end of the flat-head screwdriver underneath the top of the keyboard to pull it away from the laptop.
8
Turn the keyboard over and place it face-down on the top cover. Remove the cable connecting the keyboard to the motherboard. You may need to pull back and unlock a connector securing the cable in place.
9
Set the keyboard aside. Remove the four screws located just beneath the display panel, then remove the cable connecting the monitor to the motherboard. Carefully set the LCD display aside.
10
Remove the four screws located near the center of the top cover. Release small blue and white cable connecting the touchpad to the Gateway laptop.
11
Pull the top cover up from the base of the laptop, removing the touchpad along with it.
Regards,
Ron
Mar 04, 2011 | Gateway ID5815H-CA LX.WC502.003 Notebook
We have a desktop computer((Model: GATEWAY 838GM) misplace the ADAPTER for the CPU which one to get please thanks
sallyduby we may have some confusion here.
CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
CPU does not refer to a Personal Computer. At least not since the 1960's, and not unless you wish to confuse someone with the wrong reference. ;)
This is Gateway Support > Gateway 838GM Desktop PC > Main Support page,
http://support.gateway.com/s/PC/R/5389/5389nv.shtml
In the list click on Components.
A) There is no adapter device for the CD drive, or DVD drive, unless this is a mistaken reference to the flat ribbon data cable
B) There is no adapter device for the Harddrive, unless this is a mistaken reference to the SATA data cable that connects the SATA harddrive to the motherboard.
C) There IS possibly an adapter for the Keyboard, if you are using a Keyboard with a USB connector on the end of the cable, and are not using the original Keyboard that has a PS/2 connector.
Example;
http://www.directron.com/freeusbps2.html
D) There is no adapter for the Media Card Reader, unless this is a mistaken reference to the data cable that connects the Media Card Reader to the motherboard.
E) There are no adapters for the Ram Memory module/s.
F) There are no adapters for the Modem. The Modem plugs straight into the motherboard.
G) There are no adapters for the Motherboard, unless a USB mouse, or again a USB keyboard, is being used.
The same style of adapter for the USB Keyboard will also work for a USB mouse.
H) There is no adapter for the Power Supply, unless this is a reference to a power cable adapter that could go to a computer case fan, from a 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The 4-pin standard Peripheral power cable, and it's connector, are shown in the middle photo.
The Harddrive example/s shown is an IDE {PATA} harddrive. This style of Harddrive uses a 4-pin standard Peripheral power cable)
I) There is no adapter for the Intel Pentium 4 CPU {Processor} (3.0GHz, 800MHz FSB)
The motherboard has an LGA 775 processor socket.
The Processor has the socket holes, while the processor socket has the pins.
775 socket holes, 775 pins.
http://en.wikipedia.org/wiki/LGA_775
Unless this is a mistaken reference to the Fan/Heatsink combo that sits on top of the CPU.
Typical Fan/Heatsink combo example of Processors (CPU's) using an LGA 775 processor socket,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2943299&CatId=493
(Except the Gateway version is square)
J) No adapter for the Speakers unless I am mistaken.
Post back in a Comment, and give at least a general description of the adapter you are referencing to.
Regards,
joecoolvette
Dec 12, 2010 | Gateway 838GM (RB838GM) PC Desktop
Help?
There is a power button on your laptop which looks like ( ' )
press it for some time and it will start.you will lights coming on.if it is not coming on like that,connect your laptop to power adapter ,may be your battery is not charged
Jul 24, 2010 | Gateway MT3705 Notebook
REPLACE GATEWAY LAP TOP TOUCH PAD
HI THERE!!
Replacing the touchpad of your laptop is not difficult but because laptop parts are very delicate you need to be careful
To remove the touchpad you need to remove the top cover, also known as the palm rest
1.Power off the Gateway laptop, then disconnect the AC adapter from the power jack. Remove any other devices connected to the laptop.
2.Place your hand on a bare metal surface to release any buildup of static electricity. Close the lid to your laptop and turn the computer over.
3.Slide the battery lock over to the side to pop the battery out from its compartment.
4.Set the battery aside, then turn your computer over once again so that it's facing up. Rotate the laptop so that the back (not the bottom) is facing you.
5.Remove the two screws securing the bezel in place from the back of the laptop
6. Open the lid to the laptop, then insert a flat-head screwdriver underneath one end of the bezel to loosen it from the top cover. The bezel is located just above the keyboard, but below the monitor
7. Carefully remove the bezel the rest of the way. Insert the end of the flat-head screwdriver underneath the top of the keyboard to pull it away from the laptop.
8. Turn the keyboard over and place it face-down on the top cover. Remove the cable connecting the keyboard to the motherboard. You may need to pull back and unlock a connector securing the cable in place.
9. Set the keyboard aside. Remove the four screws located just beneath the display panel, then remove the cable connecting the monitor to the motherboard. Carefully set the LCD display aside.
10. Remove the four screws located near the center of the top cover. Release small blue and white cable connecting the touchpad to the Gateway laptop.
11.Pull the top cover up from the base of the laptop, removing the touchpad along with it.
NOTE; you can remove your touchpad and swap it out with a new one, but you can also buy a top cover with a touchpad pre-installed.
Jul 08, 2010 | Gateway MT3705 Notebook
Connecting a labtop to the modem
Kindly give more details on the problem
Dec 31, 2007 | Computers & Internet
Connecting Gateway Keyboard to Dell Laptop with PS/2>USB Adaptor
Does the entire keyboard function with the multi-adapter? I am having the same problem, and i just bought a single ps/2 to usb adapter. If it works, let me know. THanks!
Oct 15, 2007 | Gateway 2520915 Keyboard
Gateway 2520915 Keyboard Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
