Question about Frigidaire FGF316 Gas Kitchen Range
Oven temp I have read possible solutions to my problem here, but not sure if they apply to me. I can preheat oven for 2 hours, no matter what temp, and still remove the metal racks by hand. I have lit the oven manually, but still only holds a low flame. All of my burners work fine. My confusion is, even with manual lighting, the oven does not heat properly. Any advice?
    Scholar:
  • 146 Answers
How old is it? Does it have a pilot light or is it an electronic ignition or coil? If it has a pilot light you probably will need to replace the thermostat.
Posted on Dec 21, 2007
My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
HELLO,
Please carefully apply the below instruction to clean up your range
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
    There's a few things that can cause this.
    1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
    - during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
    2. If the elements are both working, then it's possible that you have a bad temperature sensor.
    - this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
    3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
    Aug 14, 2010 | Kenmore Ovens
    Oven does not get to temp when it says its preheated
    More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
    Feb 10, 2010 | GE Ovens
    Temp on oven is not correct
    Good Evening.
    I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
    You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
    Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
    Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
    Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
    Preheat takes forever
    http://www.applianceaid.com/nuker.html
    click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
    Some ohm readings and there temperature:
    Degrees F    -   Resistance
                100 - 1143 ohms
                 200 - 1350 ohms
                 300 - 1553 ohms
                 350 - 1654 ohms
                 400 - 1753 ohms
                500 - 1949 ohms
    click this link
    http://www.applianceaid.com/elecrange.html
    Mar 01, 2009 | GE Ovens
    15 yr-old GE electric oven takes over an hour to preheat to 450
    After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
    Feb 14, 2009 | GE JEM25 Microwave Oven
    Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
    some units will need to be adjusted if you live in a high altitude above 3000ft.
    Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Preheating
    hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
    May 12, 2008 | Ovens
    Frigidaire FGF316 Gas Kitchen Range Logo
    165 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Justin Duby
    Justin Duby
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
