Question about Motorola Mobility i560 Cellular Phone
Signature Bad Can't do anything with my i560, wont turn on or off.FLASHStrapFS4Cv01.00 HAB PRDBDS128H- ROMDSignature BadReady To ProgramConnect USB or RS232 data cableWhen i plug in and try to use iDEN phonebook manager the program just freezes. Any ideas?
  • excel360 Jan 30, 2008
    signature bad
    ready to program
How do I flashstrap my i560 motorola cell phone?
Posted on Dec 26, 2007
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
My cash drawer in not working
Kindly check the Data cable ( RJ11) if connected properly, connector points turned green. Try Changing it.
hope below links help you
6 pin RJ12 6P6C male connector diagram and applications pinouts RJ12 to rs232
Pinout cable and connector diagrams usb serial rs232 rj45...
Sep 13, 2012 | Partner Tech PT-8800 POS Terminal -...
I have an Olevia 42" LCD with the same problem
there rs232 to usb cable converter, you just buy it, and you got rs232 to usb connetor
Jan 11, 2011 | Olevia LT42HVi 42 in. LCD Television
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
I850: i put a boost sim in a nextel i850 and it worked f...
Sounds like the software has been corrupted...it need to be flashed to fix the software.
May 18, 2010 | Nextel i850
Need Adapter
LS4000i does not work with USB or RS232. It is an undecoded (dumb) scanner you need a LS4004 to work with RS232 and special STI adaptor for anything other then 4006, 4007 and 4008. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Sep 21, 2009 | Symbol LS 4000i Handheld
I have a canon i560 ink jet printer. the yellow light flashes and the message reads The used ink tank is full. it won't print anything
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon BubbleJet i560 InkJet Printer
Motorola Mobility i560 Cellular Phone Logo
545 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
