Question about Roadmaster (VR500CSBT)
VR500CSBT Reseting itself when I remove the faceplate
Problem: Sometimes when I turn off the car and remove the faceplate, when I place it back and turn the car on, the unit lost all settings (FM stations, bluetooth conection, etc.) and I have to set everything again.
Sometimes...
Sometimes it just works fine.
I have tried all possible combinations: turning off the radio before the car, removing the face when the car is on, turning the car off, then removing the face... etc. and I can't find the problem.
Any ideas?
p.s. I post the manual for the unit, in case somebody needs it.
  • techmike Mar 19, 2008
    Exact same issue - I ran a dedicated +12v line from the battery to the yellow wire - no help. Unit is still within 30 day warranty, so called the 800 # - they said they would send a new faceplate. 8 days so far still waiting. But I do not see how that could resolve issue - isn't the station/ bt/ setup info all stored in the main unit?
  • oviedoluna Nov 27, 2008
    VR500CSBT IS Reseting itself when I remove the faceplate sometimes yes sometimes no
Well, this has been an interesting ride. I received a new faceplate, but that actually made the problem worse - lost settings EVERY time I removed the faceplate. So they sent me a new unit. I installed it, and it worked for 10 minutes, heard a pop from the speakers, and the left channel died. They sent me a third unit, installed it and it works, but still loses settings if the faceplate is removed for longer that 2 - 3 hours. Also in AM, unit makes weird space ship type noises, even with the car's engine turned off. Now they have stopped responding to my e-mails - guess I am stuck with this turkey of a stereo. Buy one at your own risk!!!
Posted on Jul 01, 2008
No man, you should take a direct line from the car battery to the unit, then you radio station will be saved all the time, do it in specialist in cars, just tell it that
Posted on Jan 02, 2008
My phone cant pick up the bluetooth signal from sonyt xplod headunit even with bluetooth symbol showing?
Try reseting,turn the phone off and back on,then reset the head set. Follow the manufacturers instructions for setting the unit in pairing mode
Nov 23, 2014 | Sony Xplod Cdx-gt540ui Head Unit Faceplate...
I have a Sony CDX-GT310 FM/AM Compact Disc Player with detachable faceplate. The unit still plays fine, but the display on the faceplate quit working. I've tried resetting the unit as well as cutting...
check the connectors between the faceplate and the unit carfully they can get damaged with constant removing/refitting if not the faceplate and/or unit is faulty
Dec 09, 2017 | Sony CDX-GT310 CD Player
My jvc kd-r610 car receiver is not playing or anything. I blinks "protect"
JVC head units go into protect mode usually when there is a short circuit on one of the speaker wires. Sometimes this is just caused by moisture in the doors or wherever the speakers are located. The first thing to do would be to reset the unit and see if it fixes the problem. To reset the unit there is a small button behind the faceplate which you will need to push in with a pen or other sharp object. Hold this button in for a few seconds. This will reset the head unit to factory settings which does mean that you will lose all of your saved radio stations, audio settings, color settings etc. If this does not work then one of your speaker wires is probably damaged. To find out which one unplug all of the speakers, reset the unit and plug them back in one at a time. When the unit goes into protect again you have found which speaker is causing the issue. Cheers, Dan
Apr 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
No light in the radio at night
Connector from main board to faceplate may be defective or you may have liquid damage in the faceplate. Be sure you have not set the unit to the daytime setting. For repair, contact Iron Cross Audio (www.ironcrossaudio.com)
Aug 15, 2009 | Harley Davidson 426290 AM/FM Radio
System lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Mar 26, 2009 | Aiwa CDC-X444 CD Player
Garmin Nuvi won't turn on
See if you can find the reset button on the unit and push it while the unit is on. On newer units the reset button is on the back, but on older units it may have a faceplate cover around the edge of the screen you have to remove and the reset button is sometimes located under the faceplate...this may work
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
Faceplate problems
I have the same deck and a very similar problem. Mine was stuck in the out position and would beep and move a little but there was no lights or music. I called Alpine and they told me that sometimes the inner sleeve around the deck will pinch the unit a little. I took my unit out of the dash and sure enough the plastic face plate came loose and moved about 1/32 of an inch when I slide it back in place and turned the power back on it worked perfectly. Hope this helps.
May 15, 2008 | Alpine CDA-7897 CD Player
Sony CDX-GT30W faceplate
I have a faceplate for a sony cdx-gt30w. You can have it for whatever it costs for me to mail it to you. Do you still need one. I noticed you posted this a loooong time ago.
Mar 03, 2008 | Sony Xplod AM/FM CD Player w/ MP3 Playback...
Roadmaster (VR500CSBT) Logo
633 people viewed this question
Top Roadmaster Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Roadmaster Car Audio and Video Expert? Answer questions, earn points and help others
