Question about Brother MFC-7220 All-In-One Laser Printer
Dust Drum WE cannot find our manual and do not know where to find the corona wire to dust the drum?
  • 56 Answers
Ok when you pull the drum out you should see a blue tab . You take that tab and slide it back and forth and this will clean the corona wire. Now when your finished make sure the tab is placed back from where you first started. I hope this helps !
Posted on Dec 04, 2007
The fax machine is saying remove the drum there is dust on the corona wire.
Use the corona cleaning wire to clean the dust off. Open the front cover. Remove the drum/toner unit. look on the right side of the drum portion above the toner unit for a plastic tab with a triangle arrow that points to the left. Slide this tab back and forth several times. Move the tab back to the right. Reinstall the drum/toner unit. Close the front cover.
Clean the corona wire in this manner every time you change the toner/drum.
May 21, 2010 | Brother IntelliFAX 4100 Laser Fax
Fax message says dust on the drum - clean the corona wire
You should find a BLUE SLIDER on top of the Drum Unit, work it back and forth 10 times.
Feb 02, 2010 | Brother IntelliFax-2820 Laser Fax
Dust on the drum message - fax 2820 brother
There is a blue colored slider on the drum unit, move it side-to-side 10 times.
Oct 05, 2009 | Brother IntelliFax-2820 Laser Fax
Dust on drum
check corona wire, slide the blue tab 10 times check both side of drum if there is an toner on the surface of the drum try to clean it with metal polish and a cotton cloth
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
How to get rid of the ''Dust on Drum''
The dust on the drum message will persist if the corona wire cannot be cleaned by sliding the blue tab repeatedly left to right. You'll need to replace the drum unit.
Dec 26, 2008 | Brother IntelliFax-2820 Laser Fax
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Dust on drum is an issue with the corona wire. Use the blue tab on top of the drum unit. Slide it back and forth 10+ times and this should correct your issue.
Aug 07, 2008 | Brother HL 1440 Laser Printer
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Dust on Drum...
I had this problem too. I took out the drum and vacuum the drum with a vacuum cleaner ( no brush ) while at the same time manually rotate the drum cyclinder. It worked. After a month or two, you might have to do it again. But everytime, it solved the dust problem.
Nov 23, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
170 people viewed this question
James Cagle
James Cagle
Jim Keysor
