I had this problem just today and was able to fix it by checking for a drain in the forward fan compartment. In my case, the forward compartment is made of styrofoam.
Along the bottom back edge of the inside of this forward compartment, there will be a small chunk of styrofoam missing, which is the drain. I almost missed it because it was fairly small and was blocked by some black residue. Take a pipe cleaner or some wire, and push it through to clear the blockage.
If you want to prevent this problem in the future, just make the hole slightly bigger, but not too big, as you would like the majority of your cold air to stay inside and keep critters from crawling through as well.
Your unit has a clogged drain passage that's why the water is staying in the front of the unit.If you take the unit case off look for a drain trough in the bottom of the a/c where the metal wall is that the fan mounts to thats where it is,clean it out and the water will flow to the back of the a/c and not blow or drip inside your house.
for some reason the unit keeps shutting itself off. i have the "timer" turned to off but...
(More)
for some reason the unit keeps shutting itself off. i have the "timer" turned to off but it keeps switching, and turning itself off! how do i keep the ac going?
Our 12000 btu unit is making a loud noise when it changes temperature like a snapping sound. It can...
(More)
Our 12000 btu unit is making a loud noise when it changes temperature like a snapping sound. It can slide out on a chasy. Can we take it to a repair place.
i tried everything! e1 wont come off the screen. The remote doesnt work and the unit itself will...
(More)
i tried everything! e1 wont come off the screen. The remote doesnt work and the unit itself will not turn off unless i unplug it. Tried to reset and nothing turns on still. I even tried the remote for the dvd player and it still doesnt work. (that remote works the ac unit too). I tried unplugging and holding poer button too like the other responses said and nothing comes on but the e1 code and the power button is red as well. Can anyone help? Air filters are clean too.
I bought a universal remote but can't figure out the program code. The one on the website says 82,83...
(More)
I bought a universal remote but can't figure out the program code. The one on the website says 82,83 or 84 and they don't work. It's a K218E.
