Question about Rowenta DX6700 Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
THIS IS MY SECOND ROWENTA IRON IN FOUR YEARS, I LOVE IT BUT IT DOESN'T LAST. THE CALCIUM BUILDUP IS HORRIBLE. TRIED CLEANING IT WITH THE BLAST OF STEAM BUT IT'S STILL COMING OFF ON MY CLOTHES...WHAT SHOULD I DO
  • Anonymous Dec 15, 2007
    I have the same problem, i've tried a kettle cleaner which seamed to work, but now i get a dirty brown substance coming out of the iron, what can i do.
    Scholar:
  • 70 Answers
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Posted on Jul 26, 2008
  • franklindada Jan 15, 2011
    how to clean the inside of iron where water is that is where the the junk coming out on clothes. i run the steam clean setting with a hot pad glove on my arm and still it won't come clean
Only use distilled water and there will not be a buildup. I have never used tap water on any of my steam irons and have had no buildup
Posted on Apr 18, 2008
  • elbozi
    elbozi Mar 29, 2011
    I agree, the Rowenta is a fantastic Iron, but you are going to get a longer use by using distiller water, despite what the manual may say. The one I took apart had a lot of rust on parts inside, so it important to drain the iron after use to get a longer life. Water quality is going to vary from place to place, but distilled is always a safe bet.
If you are using tap water to fill your iron may I suggest buying a gallon of distilled water just for use in your iron. Here in Miami, Florida the water is very hard. My wife has owned 2 Rowenta irons in the last 10 years and hard water buildup has not been a problem. The only problem I see is the poor durability of the power cord. I am confident you will extend the life of any iron if you use distilled water.
Posted on Dec 31, 2007
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
No steam is coming out i think it needs cleaning
Some irons like Rowenta have a self cleaning feature. If yours doesn't make a solution of 1/2 vinegar and 1/2 water and put it in your iron. Plug it in and allow it to heat that up. keep working your instant steam button for a while. Hopefully the vinegar will help remove the calcium build up and let it work.
Nov 11, 2012 | Irons
I am not getting any steam. There is water in the iron but no steam is coming through on any heat setting.
Sounds like Calcium build up. My Rowenta has a self cleaning button. Does yours? Also always make sure you empty your Rowenta before you store it.
Mar 12, 2011 | Rowenta Irons
I love my iron, BUT I used to be able to clean it by the recommended method, but now it will not shoot out steam to clean the holes. It does not steam on clothes even though I prees the steam button. ...
Put in as much white vinegar as possible and then turn iron on. Let it stay on for about 30 minutes the try the steam button. Once the steam button begins to work empty the vingar an fill with distilled water to rinse. You'll need to rinse several times to get all of the vinegar out.
Sep 28, 2010 | Rowenta Irons
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Stuff coming out of the steam iron
heatman101
Apr 01, 2010 | Rowenta Powerglide DE013 Iron
Steam iron residue on suit pants
I would send them to the drycleaners and point out the contamination. If they were mine, I would treat them with a little white vinegar; the white deposits are caused by a buildup of calcium in your iron. Don't put the vinegar directly on the trousers but use a clean cloth with some vinegar on it and gently massage the deposits.
It may stink, but it is wise to now and then run it warm (only) with some white vinegar which will dissolve the deposits. Put it on a heat-proof surface (such as a stove grate) so it can stand flat otherwise not all of the deposits will get soaked with vinegar. After letting it soak warm, run several tanksful of plain water to remove the vinegar and shake it over the sink in case there is chunks (very well could be) that have been loosened.
Mar 27, 2009 | Rowenta DG-980 Iron
Brown gunge and white deposits keep coming out of the steam holes on the sole plate. We have tried de-scaling but it has had no effect. This iron has had very little use since we bought it about 18 months...
Try filling full-strength white vinegar instead of water. Then allow to steam out on scrap cloth. The white deposits are likely to be calcium. The brown gunge may be rust. When the deposits are minimized, use only distilled or bottled water from then on.
Mar 15, 2008 | Rowenta Perfect Iron
Rowenta DX6700 Iron Logo
970 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
