Question about Galaxy Radios DX- 88HL Base CB Radio
Galaxy dx99v cb radio
I have a Galaxy dx99v radio everything works but the receive. it transmits great!!!
the talk back has been disabled in the radio. can anyone tell me how to find
the cause of the receive problem? thanks,Tony B.
  • 3 Answers
Did this problem occur while radio was being operated? or when it was being worked on? or a result of being worked on?
Posted on Jan 30, 2009
    Problem Solver:
  • 8 Answers
Look here for additional help:
http://www.galaxyradios.com/updates.html
Posted on Mar 27, 2009
    Novelist:
    Champion:
  • 211 Answers
I see no one has responded to your question. The reason may be that the information is a bit vague. The are a lot of reasons a radio won't receive. In the Galaxy 99, the mic doesn't have to be connected to receive a signal so that illimates the mic possibilities. I have found that in some of the Galaxys I have worked on, that the if section ( thats the section near the pll chip, has cold solder joints ( broken solder connections to the pc board ). You may want to look real close at the pc side of the board with a magnifing glass and see if you can find any electronic components ( resistors, transistors. etc ) loose. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
Galaxy DX99V parts
how about galaxy.they still stock everything.
Mar 03, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx959 will not receive. Speaker is working. S meter is showing incoming signal.
the over power doides may be blown. you should start there .they should be marked D-1 and D-2. you may want to replace them with diodes of a higher rating.
Jun 26, 2012 | Galaxy Radios DX 959 SSB CB Radio
Will a diesel 360-3 mic ork on a galaxy dx99v
  • Hi, I can help.
  • The Diesel Electronics CB will work but you have to wire it as stated below.
  1. #1 Shield and Black - Ground
  2. #2 Yellow - Audio
  3. #3 White - Transmit
  4. #4 Red - Receive
  • I don't know if anyone before you has re-pined that mic or not so if you just remove that little Philips screw at the mic connector and then give it a quarter turn you can slide the connector out and take a look and compare the wiring. The actual numbering for the pins on the Galaxy 4 pin mic connector is as indicated below in the diagram. As you look at the mic tip make sure the indent on the mic is as it is the diagram.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy dx99v, bad squeal when I key the mic
Your microphone wires may be shorted take the mic plug apart (small screws) Now check for frayed wires touching or twisted together!
With the wires being resolderd or taped apart put back together
with the U pointing downward you shout have :
Right corner bottom Sheild ground!
Left corner bottom Black recive
Right corner top White or yellow this is Audio wire
Left corner top RED Transmit or PTT wire
If wiring looks good the problem is in the Mic take to servicer!
May 09, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
GALAXY 959 CAN TRANSMIT BUT NO RECEIVE
try the external speaker /if that is not working you may need put in a new receiving chip it is on the right side has 10 pins.
Jan 03, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
I got a dx99v cb it turns on but its not transmitting or receiveing the needle barely moves.
You may have a bad regulator transistor.
Good Luck on this problem, and I hope this has helped.
Ed Meshechek ( Radio Man )
NC Electronics
PO Box 1696
414 6th St
Mills, Wyoming
82644
307-266-4675
wyoed1@aol.com
Nov 28, 2008 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy Radios DX- 88HL Base CB Radio Logo
966 people viewed this question
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
