Question about Refrigerators
Water from bottom of freezer
I have a GE sss25kfmb (got from Sams Club). There is water dripping down from somewhere inside the freezer and leaking out onto the floor in front. I am assuming it is coming from the ice maker? But not sure, cant seem to pin point it. Ice maker use to work fine but now it gets all jamed up with ice. Any suggestions?
  • 1 more comment
  • boatday May 14, 2008
    Same problem, Ice in bottom of freezer every day.
    Even shut of icemaker and it still forms on bottom.
    Can't find out from where.
  • brasscat2000 Jul 11, 2008
    I have a Kenmore frefrigerator, ice maker was never connected, its been super hot out, now I find last few days water on floor in front of refrigerator, any ideas???
  • jfkeegan56 Sep 09, 2008
    The bottom freezer on my GE fridge has a constant drip from the top of the freezer. For now, I have just put a tray underneath to catch the drip, but I need to fix properly. Thanks in advance for your help.
Keep the leakage pipe which is backside of refrigerator outside to prevent damage to condensor
Posted on Dec 04, 2007
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
On our GE refrigerator, water leaks out of the bottom of the frame for the water/ice dispenser and down the front of the freezer side door. What could be causing this?
Did you just recently change your water filter? you need to flush 3 gallons of water out of it when changing the filter. if there is air in the line it'll drip constantly. If your ice door isnt closing all the way and properly sealing that also could be a source of water dripping. do you have a low of "Snowy" frost inside your freezer door at the ice dispenser shute?
Aug 05, 2013 | Refrigerators
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
297 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
