I turned on my dish washer this morning and with in seconds soap was running out of the machine. How do I fix it?
Comments:
Aug 25, 2009
- It was from the bottom of the door, and I believe it was just soap. I wiped it up so fast I honestly can't be sure. However when my daughter opened the door she stated that there was only suds in there, no water. Hope this helps. Thanks
It sounds like a door leak. There isn't a whole lot of water in the bottom of a dishwasher so it may just have looked like soap. Open the door and using a bright flashlight check the rubber seals carefully. Look for any torn or out of place gasket material. I think you will find that you need to have the gasket replaced which is not all that expensive.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore 24 in. 15932 Built-in
I have a Kenmore Elite dishwasher (model 665.13153K701), and the dishwasher will run through the...
(More)
I have a Kenmore Elite dishwasher (model 665.13153K701), and the dishwasher will run through the wash cycle as expected, but when it gets to the heated dry cycle (I'm assuming it is the heated dry cycle), it doesn't appear to dry. It will then flash a fault code 61 (6 short flashes of the 'clean' light, pause, and then 1 more short flash of the 'clean' light, longer pause, and repeat the code). The dishes seem to be somewhat dry, but there is certainly water on the dishes and on the tub (there is never any water standing in the tub, and the tub drians correclty). I no longer feel steam coming out of the dishwasher, and the dishes don't feel hot anymore. I am sure the dishwasher has the heated dry option selected when I run a cycle.
kenmore dishwasher will drain at the end of a cycle but then starts filling while it is still...
(More)
kenmore dishwasher will drain at the end of a cycle but then starts filling while it is still draining. if i turn it off for a moment and then back on, the draining stops and it will fill and run until the next cycle. does a bad solenoid cause it to drain and fill at the same time?
Our kenmore Ultra Quiet has blinking pots and pans and cancel lights flashing and won't cycle....
(More)
Our kenmore Ultra Quiet has blinking pots and pans and cancel lights flashing and won't cycle. Please help day after Thanksgiving...using the suggestion posted to push high temp air dry high temp air dry opened and closed the door. Now the washing light is flashing and nothing is happening.
the kenmore model 66517364300 is washing for three hours and I hit cancel and drain it. The light...
(More)
the kenmore model 66517364300 is washing for three hours and I hit cancel and drain it. The light does not change to a different task. Today it has been on the wash cyle with the washing light lit for 2 hours. When I open the dishwasher there is no water in it or attempting to drain out. Just how steam. It does start the cycle with water.
My friend's Kenmore Ultrawash Dishwasher wasn't cleaning very well, and didn't drain completely, so...
(More)
My friend's Kenmore Ultrawash Dishwasher wasn't cleaning very well, and didn't drain completely, so I helped her take it apart, rinsed the filter and looked for obstructions. Now it won't drain at all and floods the floor. Needless to say, I'm profoundly embarrassed and hoping someone knows what I did wrong. Thank you!
