Question about Dell Dimension C521 PC Desktop
Data recovery I have a dell demension c521. The service department has replaced my hard drive because my system would not boot. It made a "clicking" noise. I would like to recover the information from my old hard drive but I only have a couple of days to do this and the quotes for this service is horrible. Is there away I could recover the files myself? Also, I would feel safer if the information (once I recovered and saved any information I wanted) could be wiped from the hard drive before I sent it in to Dell. PLEASE HELP!
  • need2know404 Dec 04, 2007
    Thanks! I was hoping you were going to tell me something that I could do myself. I recently lost my job so any expense saved......You can't blame a gyrl for trying. I will try the magnet to erase anything on the drive that could be sensitive.
  • 59 Answers
let me explain first why it's making a clicking noise. Inside your hard drive is a mechanical arm that allows reading/writing stuff to your hard drive. the mechanical arm is loose thus making a clicking noise and might have damaged the platter. use this link for your referrence http://www.pantherproducts.co.uk/Articles/images/hd_lables.jpg . what needs to be done to recover your files is to take out the platter and put it in a working hard drive. I'm pretty sure that you dont have the tools to do so and your gonna need a zero dust environment to do this kind of procedure. i would advise to call drive savers. 800-4401904. to set your expectations, it actually expensive but if you have critical data there then its worth it. if you need more time for back up call dell with the same case number and ask for extended return policy for data recovery. if you want to erase your files before sending it to dell then attach a powerful magnet to the drive.
Hope this helps.
thanks
Posted on Dec 04, 2007
Return my dell-inspiron to factoy settings
Boot up with a Dell Recovery CD to format your hard disk and install a fresh copy of Windows on your laptop.
If you do not have a Recovery CD for your model laptop then you can get one from the Dell WEB site.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Sep 09, 2012 | Dell Inspiron 8200 Notebook
Dell Dim C521 power button remains orange; doesn't boot
Take a look at this document from Dell. You should have some diag lights on the front of the computer, and this should help you find what is not passing post.
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
Feb 15, 2012 | Dell Computers & Internet
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Need to reset to factore setting my dell inspiron 1501. Thanks
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 20, 2011 | Dell Inspiron 1501 Notebook
It will not start even after I replaced the power
Before anything else, open your case and make sure all power and data cables going to motherboard, disk drives, etc are firmly seated, and remove and re-install memory sticks in the same locations. Sometimes temperature changes inside the PC can cause these connections to loosen. If that doesn't fix it, do you hear the noise of the cooling fans coming on? If you do, check your monitor for a green light. If you get a green light on the monitor and fans are powered up and running and you get nothing else it could be a hard drive issue. Try booting from CD in that case. If fans come on briefly and then shut off, or fans stay on and you have no green monitor light, this could indicate an issue with your processor or motherboard.
Jun 04, 2010 | Dell Dimension C521 PC Desktop
How do I restore my Dell Dimension C521? I am
You need the C521 recovery disk, from Dell. Set the BIOS to boot from CD and start the system.
If it gives you the option of "Complete Reinstall" or "Repair", choose Complete Reinstall.
If it does not, or if it does not work - i.e., it always reads the disk and tries to maintain as much data as it can, you need to first wipe out the hard drive; there are many "Disk Wipe" utilities out there. I'd suggest using a boot disk such as DBAN (www.dban.org).
May 07, 2010 | Dell Dimension C521 PC Desktop
I want to restore my Dell Demension C521 back to factory setting
You would hit F10 before it gets to the operating system this will load it back to its factory software.
Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Disk drive not found
It sounds like the hard drive went bad. Can you see the hard drive in the bios at all? When you try and boot the computer does it say drive not found? Try booting from the vista cd and see if you can start a new installation. If you can do the intallation the drive is ok. If not the hard drive is bad.
Jun 24, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension C521 PC Desktop Logo
101 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
