My cursor goes backward first when i hit the tab key, then it goes forward. this just started. Ex. 1111 2222 3333 when i hit the tab key on 2222, my cursor jumps to 1111, then when i hit it again, it jumps to 3333
If the cursor highlight is positioned over the START button (icon) then you can select it by pressing ENTER or SPACE bar, which is the keyboard equivalent of double clicking with the mouse. To move between the fields, press the TAB key (shift TAB to go backwards or to the previously selected field).
An easy way to increase or decrease text size on most any type of Windows software is to rest your cursor over the software you are using, press and hold the Ctrl key, and then scroll the wheel on your mouse forward and backward. Pushing it forward increases text size, and going backward decreases the text size. You can also press and hold the Ctrl key and then hit either the "+" or "-" key for the same results!
To Press Move forward through tabs. CTRL+TAB Move backward through tabs. CTRL+SHIFT+TAB Move forward through options. TAB Move backward through options. SHIFT+TAB Carry out the corresponding command or select the corresponding option. ALT+Underlined letter Carry out the command for the active option or button. ENTER Select or clear the check box if the active option is a check box. SPACEBAR Select a button if the active option is a group of option buttons. Arrow keys Display Help. F1 Display the items in the active list. F4 Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
Darken the screen and either move the lid forward or backwards. Laptops have Liquid Crystal Screens and moving the lid backwards or forward will give the screen a different look.
If you need to adjust the brightness of the screen it is controlled by keys on your laptop. Most times to darken the screen you will have to hit the FN, CTRL or ALT key and hold it down while you hit the key that corresponds to the screen darken key. On some computers (even on my laptop) it will be the down arrow key, so i would press FN+the down arrow key. Remember to hold the first key down while you hit the next key. The icon used for most times to denote the brightness or darkness looks like a circular sun or a washer that goes on screws.
·Shift + F10 right-clicks. ·Win + L (XP Only): Locks keyboard. Similar to LockWorkstation. ·Win + F or F3: Open Find dialog. (All Files) F3 may notwork in some applications which use F3 for their own find dialogs. ·Win + Control + F: Open Find dialog. (Computers) ·Win + U: Open Utility Manager. ·Win + F1: Open Windows help. ·Win + Pause: Open System Properties dialog. ·Win + Tab: Cycle through taskbar buttons. Enter clicks,AppsKey or Shift + F10 right-clicks. ·Win + Shift + Tab: Cycle through taskbar buttons inreverse. ·Alt + Tab: Display CoolSwitch. More commonly known as theAltTab dialog. ·Alt + Shift + Tab: Display CoolSwitch; go in reverse. ·Alt + Escape: Send active window to the bottom of thez-order. ·Alt + Shift + Escape: Activate the window at the bottomof the z-order. ·Alt + F4: Close active window; or, if all windows areclosed, open shutdown dialog. ·Shift while a CD is loading: Bypass AutoPlay. ·Shift while login: Bypass startup folder. Only thoseapplications will be ignored which are in the startup folder, not those startedfrom the registry (MicrosoftWindowsCurrentVersionRun) ·Ctrl + Alt + Delete or Ctrl + Alt + NumpadDel (BothNumLock states): Invoke the Task Manager or NT Security dialog. ·Ctrl + Shift + Escape (2000/XP ) or (Ctrl + Alt +NumpadDot) : Invoke the task manager. On earlier OSes, acts like Ctrl + Escape. ·Printscreen: Copy screenshot of current screen toclipboard. ·Alt + Printscreen: Copy screenshot of current activewindow to clipboard. ·Ctrl + Alt + Down Arrow: Invert screen. Untested on OSesother than XP. ·Ctrl + Alt + Up Arrow: Undo inversion. ·Win + B : Move focus to systray icons.
2.) Generic
·Ctrl + C or Ctrl + Insert: Copy. ·Ctrl + X or Shift + Delete: Cut. ·Ctrl + V or Shift + Insert: Paste/Move. ·Ctrl + N: New... File, Tab, Entry, etc. ·Ctrl + S: Save. ·Ctrl + O: Open... ·Ctrl + P: Print. ·Ctrl + Z: Undo. ·Ctrl + A: Select all. ·Ctrl + F: Find... ·Ctrl+W : to close the current window ·Ctrl + F4: Close tab or child window. ·F1: Open help. ·F11: Toggle full screen mode. ·Alt or F10: Activate menu bar. ·Alt + Space: Display system menu. Same as clicking theicon on the titlebar. ·Escape: Remove focus from current control/menu, or closedialog box.
3.) Generic Navigation ·Tab: Forward one item. ·Shift + Tab: Backward one item. ·Ctrl + Tab: Cycle through tabs/child windows. ·Ctrl + Shift + Tab: Cycle backwards through tabs/childwindows. ·Enter: If a button's selected, click it, otherwise, clickdefault button. ·Space: Toggle items such as radio buttons or checkboxes. ·Alt + (Letter): Activate item corresponding to (Letter).(Letter) is the underlined letter on the item's name. ·Ctrl + Left: Move cursor to the beginning of previousword. ·Ctrl + Right: Move cursor to the beginning of next word. ·Ctrl + Up: Move cursor to beginning of previousparagraph. This and all subsequent Up/Down hotkeys in this section have onlybeen known to work in RichEdit controls. ·Ctrl + Down: Move cursor to beginning of next paragraph. ·Shift + Left: Highlight one character to the left. ·Shift + Right: Highlight one character to the right. ·Shift + Up: Highlight from current cursor position, toone line up. ·Shift + Down: Highlight from current cursor position, toone line down. ·Ctrl + Shift + Left: Highlight to beginning of previousword. ·Ctrl + Shift + Right: Highlight to beginning of nextword. ·Ctrl + Shift + Up: Highlight to beginning of previousparagraph. ·Ctrl + Shift + Down: Highlight to beginning of nextparagraph. ·Home: Move cursor to top of a scrollable control. ·End: Move cursor to bottom of a scrollable control.
Remove steering column shroud(cover)and tap ignition barrel with small hammer while twisting key backwards and forwards,also turn steering wheel backwards and forwards sometimes this is enough to release key as the locking pins in barrel and the steering lock pin do sometimes jam.You will have to remove steering column shroud to replace ignition barrel if tapping/hitting it doesnt work anyway so its not a wasted effort.Good luck,let me know how it works out
