Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU430UC/06 The dishwasher is stuck on rinse/dry cycle. The run times have been getting longer for the last few weeks. and now the cycle stays on rinse/ dry. The pump still runs and I hear water splashing normally.
  • Judy Curtiss
    Judy Curtiss Dec 27, 2007
    Ditto... I opened up the panel thinking that the circuit board was burned at a solder point; this wasn't the problem. I believe that the pump continues to run when it is on the Rinse/ Dry cycle. I can't get it to leave this cycle. Is there some way to reset this once it reaches this point? Is there a cost effective fix that a home DIY'er can do?
  • edwards_mj Dec 28, 2007
    I have a similar problem. $375 for a service call and a new control panel I think the machine is still taking way too long. Does anyone know what the "cycle time" is for the "normal wash" setting including wash, rinse & dry?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Ok first of all there is a drain pump and wash motor pump. which one is running?Then tell me what kind of buttons u have.Are the touch buttons or plastic buttons that move
Posted on Dec 15, 2007
Bosch Dishwasher Model # SHU53E02UC/14 started running about 3 times longer than it should and its not cleaning very well.
If the Rinse cycles completes within the normal time, but other cycles are slow - particularly a Heavy or Super Scrub cycle - it is most likely that the water heating is not happening or is very slow. The control will not advance (proceed) the cycle until the temperature sensor signals the control board that the water temperature is correct. Otherwise the control will wait, indefinitely, for the heating to happen. This also affects cleaning and drying performance. Loose wire connectors, bad heater, bad temperature sensors or a bad controller are possibilities.
Oct 10, 2016 | Bosch Dishwashers
Bosch dishwasher stuck wash cycle
If you post your model number I and others may be able to help you further.
Short of that, it sounds like, the dishwasher stops because it's waiting for the water to get to the right temperature before it advances. If you open the door and the water is cold, you need to replace your heater because it's not heating the water. If the water is really hot, then replace the thermostat inside the door because it's not reading the water temperature correctly and advancing the timer.
Dec 16, 2013 | Dishwashers
Hi, I have an BOSH dishwasher SGV4313gb/17. It is about 8yrs old and has worked fine until last week when it did not complete its cycle. Have reset and it seems to complete cycle but I don't think it...
Are you using a rinse aid? if so and teh dishes are still not drying properly, try adjusting the setting for the rinse aid dispenser. Open the door of the dishwasher, open the flap where you pour in the rinse aid and look for the cirlce with the arrow and nunbers on it. If it is set low (1 or 2) try turning the arrow to a higher number. If that adjustment doesn't work, increase again and again until the dishes are dry.
Jan 05, 2011 | Bosch Dishwashers
Bosch SMU7052UC gets stuck in wash cycle. Pressing alot of buttons, on/off, I can move it to rinse where it sticks again. No drying either. Any suggestions?
I have a 10 year old Bosch SMU 7000 and the drying function has ceased. Dishes are wet after all cycles. From what Ive read this isn't worth fixing because Bosch are so difficult to get into.
Jan 23, 2010 | Bosch 24 in. SMU70 Built-in Dishwasher
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Endless cycle with wet dishes
If it's a Bosch, check for Rinse Agent (e.g. JetDry). Rinse agent is not optional with a Bosch.
Apr 14, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwaser is stuck in Rinse/Dry cycle
It could be a sensor or timer solenoid in the dishwasher maybe broken and needs replacing.
http://www.repairclinic.com/bosch-dishwasher-parts-gg.htm
Apr 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
606 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
