Question about Sony KP-57WS500 57" Rear Projection Television
2002 Sony 57 inch XBR
I just got a HDTV box from my cable company and hooked it up to the TV, I believe I have hooked it up properly, but I do not feel that the picture quality is all that much better. Above the red, green and blue inputs are inputs that read HD and VD, should something be going into those?
    Problem Solver:
  • 10 Answers
YOU MAY NOT HAVE THE HD COMPONENT CABLES AND CONNECT THEM TO ONE OF THE VIDEO LINES..
Posted on Dec 15, 2007
Hoow do I connect sony xbr trinitron TV to HDMI cable.
Refer its user manual for details. If you do not have the user manual. try the site linked here, and download it for free. www.retrevo.com/
Electro help
Sep 12, 2014 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Jan 05, 2013 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
I just got a Sony Bravia 40 inch lcd 1080p high def tv. I am able to pick up a dvd picture on it, but I am having trouble finding my cable channels. I do have a cable box, and it is hooked in there...
When I installed my dads Samsung 40 lcd 120 hz. I had to turn it all off and after 5 mins I turned on the cable and then 5 minutes later I turned o the tv.
Or have you tried "searching" the tv for cable channel's?
Jun 17, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony KP-57WS500 57" Rear Projection Television Logo
344 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
