Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam DP-01 FX/CD
I only have the demo and one other song on my portastudio and it will not let me record or use any record type functions. The message that comes up in the window when I push the record button says MEMORY POOR PRESS EXIT. I bought this unit in February of 2007. I'm getting zero help
from the people at tascam. Hope that maybe someone else has had this
problem and has a solution.
Check to find out the size of the active FAT partition. You may have a 'less than optimum' amount of memory left in that partition. Switch to another partition and see if you can record in that one.
Posted on Dec 10, 2007
How do I set my Tascam DP-32 to record 24 bit 48kHz?
Dustin, just go to song in the menu , click the arrow to song load, create etc. cursor to song create and it will give you the option of 16 or 24 bits just turn the cursor wheel then just cursor down with the button and select 44.1 or 48 kHz . Then cursor up to song load and push the right arrow and it will load your song with the settings you have selected. Very good recorder once you learn your way around on it. Joe
Nov 12, 2014 | Tascam DP-32 32-Track Digital Portastudio
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam dp01 fx cd.. OOPS!!! Please help.
Depending on the voltage that your laptop uses, if that voltage exceeds the Tascam required voltage you might have burned out the Tascam power board. Not good. I know you don't want to replace the entire unit. Try contacting Tascam directly they might give your an alternative in just replacing the power assembly.
Sep 20, 2008 | Tascam DP01 All-In-One Recording Package...
DP 02 Info
Can't help you with any books for the DP 02, but I can try to assist you in doing what you'd like to do.
The way I would attempt to do this, and there may be other ways but this is really the cleanest in my opinion, (assuming you have access to a computer) is to first rip the CD onto your computer into a series of wav files. Then you'll want to work with one song/CD track at a time. Then you'll need to use a WAV editor (Audacity is a good free one) to convert the wav file from STEREO into MONO wav file. You can then (using the USB import function on the DP-02) import the mono WAV file into the DP-02's fat partition. From there you can load it into the DP-02 by choosing which track to load it into. You'd then be able to play this track while recording your voice overdubs onto another track.
You'd then mix your song and you could burn onto a cd right from the DP-02 (or do as I do and export the mix as two mono wav files back onto your PC and, then convert them back to stereo and when you have all the songs you want for the CD burn a new CD from your PC).
You may have to consult the manual for how to use the USB import/export as well as how to record and mixdown, but I've tried to outline the basic process to do what you want which wouldn't be discussed int he manual.
Hope this helps.
Sep 08, 2008 | Tascam 2488 Portastudio Multitrack...
What kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Jan 24, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
88 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
