Question about D-Link AirPlus DI-524 Wireless Router
Security enabled d link router
Hi. i got a D-Link xtreme G router from a friend sans cd installer. how can i put a password on it so as to make my internet secure from hackers and anauthorized use by people with wi-fi capabilities?
thank you in advanced.
'rj
  • rjoson Dec 10, 2007
    thanks for the help. still can't figure it out, but may be there ae other causes which i haven't discovered yet.
    Scholar:
  • 130 Answers
If you got it from a friend, the first thing you should do is take a paper clip, and look in the back of the router for a little hole labelled "Reset". This will reset the router to the default settings. With the unit on, press this button for about 10 seconds. After this, hook up the router, by ethernet connection to your pc. Once the connection is made to your pc, and the router is on, go to http://192.168.0.1/ or http://192.168.1.1/ depending on the exact model. It will ask you for a username/password. The user name is "admin", and there is no password. From there, you are in the router configuration. Click "Wireless" on the left of the page to edit your wireless configuration. Click apply when you have everything set to your liking, and you're done!
Posted on Dec 04, 2007
I have to D-link xtreme N DIR-655, how can i use the other router as an access point?
You need to configure router with below method. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Connect Internet cable to router's WAN port. Let me know if you need further assistance. Thanks for using FixYa.
Jun 19, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I HAVE RESET MY D LINK 624 ROUTER MODEL DI 624 BUT NOW IT IS NOT SECURED. I Had to do this as i forgot password I can't find out how to secure with a new password help help
1. You will have to use the CD that came with the router and go through the "setup Wizard" and establish a new password.
2. contact your ISP ( internet service provider0 and get the information to input into the router to connect properly to the internet.
3. Go to the D-link page and an instruction set for your model router is there to guide you through the setup.
Jun 14, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Does the d-link airplus xtreme g model DI-624 support WPS?
yes there is RESET or WPS button for RESET all settings to factory defaults. For that press RESET/WPS button for 1 seconds it is in the back side of router. Then all settings defaults . You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 03, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need to put a security code on my wireless router so my neighbors cant use it but i am unsure how to do this.
Use the cd that came with the Router. Run the cd like you did when you first got it. You should come to a point where it recommends a WPA security. Click it. Then you just have to create a password. Complete the rest of the setup. Then you will have to go to any device connected through the router and put in the password. That should keep your neighbor from leeching off you.
Feb 01, 2011 | D-Link Xtreme N DIR-655 Wireless Router
HOW TO SET UP SECURITY
Hi Friend,
Please follow the steps:
1.Click Start\Run\ type cmd and hit enter.
2.Type ipconfig and hit enter (in the black window)
3.Note down the default gateway and exit from the black window.
4.Open the web browser and type that default gateway in the address bar and hit enter.
5.Enter the username and password if prompted.
6.Click Wireless and click Security and select WPA from the dropdown
7.Select TKIP in Cipher type and PSK in PSK/EAP
8.Enter any ten digit number as Passphrase and confirm it again and click Apply. this will help you to enable security on your router. You can use this passphrase whenever you try to connect any wireless devices to the router.
I hope this will resolv the issue.
Regards
Chiranjeet
Dec 08, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have no cd to set it up
You can set your router settings without disk too.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
If you need user name and password for connect to your service prtovider then configurayour router as PPPOe .
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Feb 07, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
How can I reconfigure my access point on my DI-624 to 802.11a?
First press reset button for 10 seconds it is in back side of router.
Then connect router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page.
Enable DHCP if you want to get ip from router for your LAN.
Go to wireless enable it .
Then enable wi fi security wep security then enter WEP key it is your password to connect internet .
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 ROUTER INSTALL WITH OUT CD
Disconnect your modem and other devices from your wireless router and connect your laptop/PC to your wireless router through ethernet port ( keep your ip settings to automatic in network settings of your Laptop/PC) then type the ip number 192.168.0.1 in your web browser's address bar.
Here you are you will get the login page of your router.Default login id is "admin" and password is "password" if this password is wrong then try with the password "admin".
After logging into the page you will find the wireless security tab.in that you can find your security key.
May 12, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router Security
Once you connect to your wireless network and it ask you for a password or if you notice that your wireless network name has a lock on it or says it is secured. It means your wireless network is secured. Otherwise reconfigure your wireless to enable wireless encryption.
Jan 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router Security
To be more specific, type 192.168.0.1 into your internet url box, and put in your password, then go to wireless settings, then security, then enable either 128-bit wep or wpa encryption and press 'Apply' or similar.
Hope this helps
Chris (ziraffa)
Dec 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus DI-524 Wireless Router Logo
306 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
