Question about Sharp AL 1631 Copier
Sharp AL-1631 Out of Paper
Copier unable to pick up paper. Also its making a clicking noise. Any ideas?
    Scholar:
  • 53 Answers
Could be quite nasty, that one! Open RH side door, Is there any obvious spill ot toner, particularly toward the back of the machine?
Could be helpful to pull out the toner unit and the drum unit....can you now see toner spilll? If the toner /developer mix has leaked into the magnetic clutches at the back, the developer will be attracted to the clutches and interfere with their operation. This is a quite common fault with some of these machines.Unfortunately prevention is better than cure, and vacuuming the toner before it gets into the works is the only real cure. Once into the clutches it is one heck of a job to successfully fix it....Sorry....let's hope that's not the problem
Posted on Dec 05, 2007
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
My copier wont pull the paper from the tray...it has a full load of paper in it but when I go to try and make the copy it won't pick it up and then it flashes "P" like it is out of paper
Have you taking out the paper tray and look inside for a piece of paper jammed behind the paper tray. Also, make sure the paper guides in the paper tray are tight against the paper in the tray & make sure the copier is on a level surface. You may also, need the paper feed rollers or clutch. If you need to make copies, use the by - pass tray on the right side.
Apr 05, 2010 | Sharp AL 1631 Copier
When copying from the SPF the paper misfeeds. It starts through but the goes crooked.
You need to adjust the SPF paper size knob to fit your size of paper freely. Make sure that area is clean or you can wipe with a clean damp cloth the picking roller which is located there.
Dec 23, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
1/8 black lines on Sharp AL-1631 copier
Have you cleaned the narrow glass next to the platen where the originals are scanned across when using the auto feeder?
Feb 17, 2009 | Sharp AL 1631 Copier
Could not pick up papers from paper tray.
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Aug 30, 2008 | Sharp AL 1631 Copier
Jammed paper
where is it jamming ? pick up, on the side in the fuser where it gets hot???
Jul 17, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
