Question about PfaFF Tiptronic 2030
Plase explain how to use 1222 machine since i am using it for the first time
The thread is breaking as soon as i start using the machine
5 Suggested Answers
  • 632 Answers
SOURCE: needle cannot be secured in PFAFF 1222 sowing
Well if you stripped it then there is no magic fix for it except to replace it. It's pretty hard finding the correct tap fixing the stripped threads.
Posted on Aug 10, 2009
adadoug
  • 682 Answers
SOURCE: top thread breaking
I would try loosening the tension a little. Is it real cheap thread? Sometimes that will give you a problem. I would look into the owners manual for more suggestions.
Posted on Feb 12, 2012
SOURCE: Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Posted on Mar 12, 2012
SOURCE: The thread from the spool breaks immediately. Does it need a particular kind?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Posted on Oct 13, 2012
The thread is breaking the whole time, what could possibly be the problem?
Could be several things, ie mis-threading, burr or snag is catching the thread, old/bargain bin thread, needle is not compatible with thread and fabric, tension is incorrect...
The first thing to try (and also the least expensive), install a brand new needle.
Remove the upper thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Feb 25, 2017 | Sewing Machines
All of a sudden , as soon as i finish sewing a piece of fabric the thread will break. i can continue to sew as the main machine is still threaded.
There may be a bit of thread stuck in the bobbin or somewhere under the machine. Turn the machine sideways and look with a flashlight. Then turn the wheel a couple times and look again...Good Luck...xo
Sep 20, 2014 | Sewing Machines
The top thread keeps shredding/ripping while trying to embroider. Using a babylock ellure.
as you thread the machine check for burrs, also on the needle plate
Feb 24, 2014 | Baby Lock Ellure
Thread the needles
cheap thread will break easily. Make sure you buy good quality thread. If you want to test to see if this is what your problem is, buy four small spools of Coats and Clark thread, I even use it for embroidering. It doesn't break easily. If it doesn't break, it is your thread. If it breaks, your tension is too tight on your machine.
Oct 16, 2017 | Sewing Machines
Upper thread breaks
Oct 12, 2012 | PfaFF Sewing Machines
Mar 11, 2012 | PfaFF Sewing Machines
I am having a problem with thread breaking. as it's going threw the needle it starts to back up father up on the thread and then it just keeps getting thinner and thinner until it breaks. It is hard...
try a different spool of thread & see if that solves the problem ,, I've gotten thread that would easily break & just used it for sewing quilt squares,,,if another spool does not help try a new needle
Sep 08, 2011 | Baby Lock Sewing Machines
Skipping stitches and sometime the thread breaks.
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Mar 27, 2017 | PfaFF Sewing Machines
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
130 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
