ASUS Eee 4G Notebook Logo
Posted on Aug 25, 2009
Blue screen when i start my eepc but can see the taskbar below
I can't use the task bar and the screen is in blue.
Anonymous
Level 1:
  • Contributor 28 Answers
  • Posted on Aug 25, 2009
Anonymous
Contributor
Level 1:
Answers
28
Questions
0
Helped
7654
Points
70
Try to tell to an Supplier, and follow all the instructions.
Peace!
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
MENU BAR IS GONE...PUFF, GONE
Press ctrl+esc to see if the start menu pops up, if it does not then proceed by trying the following steps below.
Make sure explorer.exe is still running:
Press ctrl+alt+delete to get into Task Manager and do File -> New Task -> explorer.exe -> OK
Otherwise check to see if your task bar is auto hiding:
Move the cursor to all four edges of the screen in an attempt to locate the hiding task bar. If the task bar does pop up, right click on it and press properties. Proceed by unchecking Auto-hide the taskbar under the Taskbar tab and pressing Apply and OK.
If all else fails, try rebooting the PC.
THE TASK BAR APPEARS AT THE TOP OF THE WINDOW
First, make sure the taskbar is not locked. Right click the taskbar and make sure the is no check mark beside 'Lock the taskbar".
Now, point your cursor just beside the START button (outside the START orb and on the task bar), click and hold and now you can move it to the bottom of the window.
Task bar consumes two rows at bottom of screen
Hi, try this to fix the problem. [right] click on the "Taskbar" select to open the "Properties" short-cut, next in the [Taskbar and Start Menu...] window, click on the Taskbar button, and [un-check] every box. Next, open the Toolbars window, and [un-check] every box, "Apply and OK changes." After you have finished doing so, "restart" the Computer. When you are back to the "Desktop window, open the Taskbar Properties again, and put a {Check mark in all the boxes of the items you want present, to view}. I hope that it works for you; thanks for using Fix'Ya, and if you find the time give a "rating" for the help, thanks again.
1helpful
I want to change the position of task bar from vertical to horizontal.
In order to move your taskbar to different sides of the screen, first right-click on the task bar and un check "Lock the Taskbar".and drag it in the direction that you want. When you have it positioned, right click and select "Lock the Taskbar" to keep it where you have it set
1helpful
3answers
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
1helpful
Desktop icons and task bar not showing just blue screen on login
Press Ctrl+Alt+Delete when you get to the desktop, when it comes up click on FILE then on NEW TASK (RUN), type EXPLORER.EXE and press enter, this should bring your icons and taskbar back.
Once you have them back, click START then RUN and type SFC /SCANNOW and press enter.
PS. Note the space between C and /
1helpful
Only task bar shows up when eee pc is turned on
I had the exact same problem, what helped me out was restoring to factory settings.. When turning it on, press f9 repeatedly right away until a screen pops up with 3 options. choose the option "restore factory settings" or whatever its called and then type in yes. This is restore your eepc to the way it was when you first bought it. It will erase all your personal data, and changes, but it will give you your desktop back!!
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
