Question about Intel D101GGC Motherboard
Compaq presario sr1012nx
After turning off and power is disconnected it will not boot up it acts as if its dead if i connect the pwr on and off it will come on ,if i keep power to it it starts most of the time
  • 97 Answers
The battery of your computer is not properly working due to some short in the circuits. Or maybe your batery is now depending on the adaptor.
Posted on Feb 07, 2008
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
I have a compaq presario v3000 but the bios cant detect my hard drive, it seems that there is no power coming into the hard drive, the hard drive is tested on other unit but it work just fine.. i hope...
it is the mother board disconnect pwr...take out battery...use hot soldering iron with smallest tip and reheat connector wires if you can...
let us know what you did
Nov 25, 2010 | HP Compaq Presario v3000z Notebook
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
Your battery might be defective.
A fast check to verify this is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then battery is defective & need to be replaced.
Nov 04, 2009 | HP Compaq Presario 2145US Notebook
Compaq presario m2000 imediately shuts down after
Check for blocked air passages - vacuum out the fan ports. (Don't use canned air - you'll just blow the dust inside, where it will act as an insulator and help things overheat.) Make sure the fans are actually turning. If there's any mold growing inside, that could cause the problem too.And for more contact
Jun 18, 2009 | Compaq Presario M2000 Notebook
Compaq logo
It appears that the hard disk drive is not being seen in the Bios. Ensure that both the power and data cables are connected to the drive and the controller. try booting again.
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Presario will not start
Hi, remove the left side of your case, turn on power and see if you can see a red or green led light on the board, if its not showing then your power supply is faulty. If the light is on then with the power off check the RAM chips are tight. if that does'nt work Then trace the cables from the front of the case, locate which is the pwr switch and unplug that, turn the poweron and then use a small screw driver and bridge the pins of the pwr switch. If this does not work you have either a dead CPU or a dead motherboard. Regards mistyman
Oct 07, 2007 | Generic Memory Compaq Presario SR1215CL by...
Intel D101GGC Motherboard Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
