Question about Ovens
Oven lock engaging and disengaging
I have a frigidaire fgf355cgsc.
It was in storage for 2 yrs.
Hooked it up. all works well except for auto lock.
The light is on for the lock mode, and at 30 second intervals it locks and unlocks. It will not stop. Can not use any part of the oven or broiler due to this. Tried doing the self cleaning mode, and when completed, it started all over again. It has ben doing this for 3 days now.
How do I cancel this locking and unlocking mode so my oven can be used?
  • 1 more comment
  • Christine Mirabelli Dec 06, 2007
    Mine is a self-cleaning regular and convection single oven, and when I run the self-cleaning mode, the door locks and won't re-open. I did it again yesterday, and it's stuck again! I tried turning off the circuit breaker for 30 seconds and then restarting -- that didn't work. I tried turning off the circuit breaker for 1/2 hour, and that didn't work. I tried starting the cleaning cycle again and then cancelling it, and that didn't work. Now what?
  • Anonymous Dec 21, 2007
    I have the same problem as mammababe. The oven door will not open after selfcleaning. I tried to turn off and on the circuit braker. it did not help.
  • jodielwm Mar 03, 2008
    the oven door will not unlock after the self cleaning is done
Unplug the oven from the outlet, and wait 24 hours or overnight, and plug it back in. It should unlock and work ok.
Posted on May 25, 2008
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
I have a frigidaire self cleanig oven and I want to clean it. I pushed the clean button and it lopcks the door but it does not get hot and act like it is cleaning. The oven is over 6 yrs old
These may be dumb questions... but do your bake and broil typically work correctly? What model do you have?
Depending on model, you should be able to press clean, high or low (2 or 3 hrs), then clean again. At that point the door should lock and the bake element should begin to get hot.
Aug 29, 2011 | Frigidaire Ovens
My oven lock is on and will not come off
you can hold the clear/off button for 3-5 seconds this hsould realse the lock.if not you can temporarily remove te back cover and remove the motor.sometime unplugging the unit may relase the lock
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have Amana Insta-Broil self clean oven. The broil is working but not the oven. Any suggestions?
my amana self cleaning oven was in storage for 2 yrs. Hooked it up and all burners work and broiler but oven won't kick on.
Dec 26, 2009 | Amana Ovens
I started to clean the oven and just befor the lock locked, I checked inside. The oven door now is stuck and the lock engaged. What can I do?
Hi
Try switching the power off at the wall switch and then back on again. It may be that you also have to wait for the oven to go through the clean cycle as it is safety locked during auto clean.
Nov 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
Jan 21, 2008 | Frigidaire 27 in. Electric Double...
Ovens Logo
264 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
