Question about Mitsubishi WS-65807 65" Rear Projection Television
67" rear projection Mitsubishi....
For the past year, the tv would work great one day, the next the picture would only work on 1/2 the screen... The next day the whole picture would come back but be really wavy... The next day the picture would be perfect again...
NOW... I don't have any picture. Push the power button and the little green light comes on (steady) and no picture at all.....no flicker or anything...
Suggestions?
  • Jamie Dilla Dec 04, 2007
    Huh? I"m a tech "know nothing"... Put me under the hood of a car and I'm a master....but this TV is driving me nuts!
    President:
  • 4,402 Answers
Sounds like a cold solder joint, turn the main pcb over and see if you find any cracked solder or where the solder looks like it got hot.
Posted on Dec 04, 2007
  • Cary Farah
    Cary Farah Dec 04, 2007
    I guess i would have a service repair guy come out and look at it.
    you could tap on the board but you could cause more damage. and there is high voltage in there set!
Plasma TV Repair
Hi ,
get the power supply checked and the screen back light too. if possible change the screen .
peace .
May 18, 2017 | Televison & Video
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Picture started getting fuzzy then it went out
yes,remove the back of the tv,on the power board you will see the problem.replace those capacitors on the power board.this will allow the set to work.the black bars may still be there.this is an indication of a bad panel.
Aug 08, 2009 | Televison & Video
Blur picture
First check the antenna! After that, look for colour changes/ shadows alongside text on screen, of some particular colour. Has the set been dropped? If so, static convergence can be knocked out, you need a professional.
If it is just generally blurred, obviously something has changed, but it might respond to adjustment of the focus control (inside set). This is still a job for a serviceman if you don't know anything about TV circuitry.
Mar 25, 2008 | Sanyo DS27225 TV
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
