Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag fav6800aww wont spin
The washerstops about 6 mintes into a cycle and then cycles on andoff but doesnt continue washing, i have pulled the cover, checked the tech code sheet, can manually pump the water out, it can do everything else but make it spin. No error codes show up either. Pulled the JP4 connector and ran the motor board test, it makes noise and then spins for a few seconds but the belt doesnt spin, which may be normal. I am wondering if when you wash and it reachesa point it needs to drain the water does the cyce spin at the same time (we are talking about 6 minutes into the wash load), which could be why th load stops cause it keeps tring to spin. software version is 3.17t, board input test 117ot, output showed just ot, all of these checked out ok - hot water, fabric softener, bleach valve, cod water, drain pump, lid lock - so i know there isnt a blockage in the drain hose.
HELP !!!!!!!! - I dont want to spend $170 on a new motor board when it ppears to work fine for something that turns out to be simple.
  • 14 more comments
  • SADIMAENOT Dec 05, 2007
    WASHER WONT SPIN IT SHOWS NUMEROUS CODES
  • dave_tucson Dec 09, 2007
    My washer model FAV6800AWQ starts a cycle and never finishes. It has no fault codes, however will continue in the wash cycle and never goes to the spin and drain cycle. I am guessing it is the control board. Any suggestions?
  • RockyTop Dec 17, 2007
    All wash cycle selections stop about 6 minutes into cycle. Every minute or so you can hear what I think are the agitators turning and then it stops and starts again. The Spin Cycle will not work so as to empty the remaining water in the tub. Basically appears to be the same problem as others have reported. If anyone has had repaired, please post what was replaced & approximate cost. This machine is only 3 years old and washes an average of 3 to 4 loads per week.
  • Anytire Jan 07, 2008
    My fav6800awq (bisque) goes out of balance, has several codes, reads dc. and once uC. Tested everyhing and think it is the clutch. There is an updated clutch after 2005. This appears to stop the high speed spinout which results in water in the tub. A&E guy said tub displacement sensor bad, I tested it two ways and believe him to be wrong. It is doing what it is supposed to. Any other thoughts or ideas?
  • Rottiecrew Jan 21, 2008
    does anyone know where I can get the pdf for of the repair manual for this washer as well as I ordered the bearings online as suggested above, but that wasw before i knew there were seals as well - where can i get just the seals - and the repair manual pdf is so i know how to put the bearings in
  • jessie10 Feb 14, 2008
    My Maytag Neptune FAV6800 AWW keeps shutting off with the error code UC. It leaves some water in the tub. I hit the Pause button and check the load which is off to one side of the tub. I readjust the load and hit the Start button. The first thing the machine does is to readjust the load again so that it is off to one side. Then it tries to spin and the error code UC comes up again. The clutch, water pump, and load sensors have been replaced by an authorized Maytag repair service. I am waiting for the fourth service call. They say this cannot be fixed and the machine has to be 'junked." It is 2 1/2 years old and I am out $1,000.00 plus tax, delivery, and warranty expense. They will give me a $500 credit at Sears only because I purchased the warranty for $200. Net loss is $900.00.
  • Anonymous Apr 09, 2008
    April 9, 2008. Washer would not drain NO error codes, would do everything till time to drain, then would cycle through trying to drain FOREVER, turned off and unplugged. Called A&E tech arrived in 2 days (not bad, $72 charge). He thought it was the control board, I asked to make sure, due to the part and return service being 10 days WOW, I decided I would install. To my dismay control board damaged, called and had them order another, good thing the control board is under warrany. the day before the scheduled appointment, the 2nd control board arrived, looked good replaced and still same problem, started looking at the manual and thought of the clutch. The next day tech showed up and asked if it could be the clutch. He was'nt sure. I said I bet it is! Sure enough 3 hours later and $350 bucks it was the clutch, bearings were bad. This washer is pretty simple next time I will make time to fix myself if it is mechanical.
  • RixRUs Apr 12, 2008
    I just got up this morning to the sound of my Neptune TL washer still trying to go into spin, over and over. It was still at 38 minutes, where it was last night when I checked it beofre I went to bed. It will not go into the spin, even when I set it on just the spin cycle. Sounds just like the same problem all of you have had. I am so glad you posted this site, so I don't get sucked into the costly repair. Mine is 3 years old also.... I think we can fix this ouselves. At least I know what is causing it. Thnaks for he info. I could not find my mnaual this mormnng.
  • Anonymous May 08, 2008
    My washer will go out of balance no matter what size the load. I've check the codes out and the tube balances arm out and there seems to be no problem .
  • Anonymous May 11, 2008
    Same problem It is stuck in the spin cycle and won't empty the water and spin. It sounds like it keeps trying but just stops ans code pc comes up after about 5 or 6 minutes.
  • Anonymous May 14, 2008
    We have a 3 year old FAV6800Aw Problems with the spin cycle. The machine keeps trying to readjust the load no matter what the size. I have taken the advice of the other posted issues regarding the clutch. I removed the clutch without any problem and ordered a new one. I noticed the bearings to be pretty dry and sticky. The sleeve that travels on the bearings did turn freely but only one direction? I am assuming this is part of the bearing design to allow the spring steel coil to work as designed for the clutch assembly? I repacked the bearings but since I already have a clutch assembly coming in tomorrow I will install the new one. The question is, Should the bearing sleeve only turn one direction "Counter Clockwise"? If the bearing has failed could this cause the in-tub agitators to continue to rotate introducing the out of balance spin cycle issue?
  • Anonymous May 17, 2008
    I have the same problem with my Neptune FAV6800. I spent $88 to get a wrong diagnosis- the tech thought it was the control board but it was not and ended up being the clutch which he estimates to be $180 and the repair labor charge to be $350. Does anyone have a solution for me?
  • honeybeae Aug 06, 2008
    My machine stop after 10 min, of starting. It shows a nf or of. Not sure what that means. And it also will do 2 loads and it I went to do a 3rd load it will not start. HELP
  • SBAR56 Oct 29, 2008
    I had the same spin problem and my machine is onlly three months old. The first repair service replaced the tub displacement sensor assembly. The washer started spinning again but only for one load of cloths. I complained to the store where I purchased the machine and he suggested a different repair service. That service repaced the clutch.
    PROBLEM SOLVED!!
    If you are having 'UC' or 'dc' errors I suggest that you ask your repair man to replace the pulley & clutch.
  • FAV6800A FAV9800A
    FAV6800A FAV9800A May 11, 2010
    question for maj7th tyou are still out there. How did you drive out the outer tub bearings? Did you use this tool to remove amd install the Spinner Nut? Thank you......Rich
  • Anonymous Mar 22, 2014
    I replaced the wax motors and it works the first time but on the second wash it doesn't
I have a 3 year old neptune top load and have experienced the same problems you all have had here. Problem: Washer was leaking 1/2 gallon of water every load and sounded like a freight train on spin cycle. I usually do my own repairs but didn't have time so I called A&E by the recommendation of Maytag. Diagnosis! The tech said the tob o-ring seal was bad as well as the transmission. I had no reason to dought this professional right. I did after he told me the price... $450 to fix it!!!! I reluctantly gave him his $65 service call fee and said goodbye..
I called maytag and they said the transmission should have been covered by warranty (10 years). The tech was either an idiot or just plain trying to rip me off. I called Maytag back and they sent me the supposed bad tranmission and seals. I replaced them in 1/2 an hour. Guess what.... This did not fix the leaking or the loud spin cycle noise. What is the problem with this neptune model? The problem for every owner including myself has at minimum been the main seal inside the outer tub. This leaking for months took out the bearings causing the noisy spin cycle. I replaced both 6207-2rs bearings compliments of ebay for $6ea. After reassembly it was like new for the first load. On the second load it would stop on the spin cycle.... It would cycle between the agitators and trying to spin but never engaging into spin. After 5-6 minutes it gave me the code that stated an unbalanced load. What the problem was is the leaking had made its way into the clutch as well. I pulled the clutch/pulley back of and cleaned and lubed it. Problem solved! She now goes into spin and has no problems whatsoever. I'll never call A&E again...Mechanically this washer is a piece of cake to work on. Electronically it could be a bear... The bearing replacement took approx. 2 hours total from start to finish. Next time I'm buying Kenmore and the extended warranty. I'm tired of screwing with this junk... Good luck guys.... Jos Roach... CA.
Posted on Jan 19, 2008
This looks like what I have. It would wash and depending on the cycle, it would stop around the 21-26 min mark or 12 if I was doing a quick wash. I took the front panel off and noticed that when it went to spin, it would go in one direction for a few seconds and then reverse and move and hesitate and stop> I took the belt off and the clutch assembly would spin freely in one direction and not the other. i removed the tub itself and took the clutch off, the bearings had seized up. i replaced the clutch assembly, old one was definetly bad. after replacing clutch, I discovered the motor is now bad, probably due to the clutch siezing up. Good news is motor is covered by Maytag for 5 years, I have about 3 months left on the 5 years. I will update after I replace the motor. Clutch is aprox 140.00.
Posted on Dec 18, 2008
Sometimes when the spin cicle start make a stumble noise not to hard and suddenly stops, and keep doing the same until the end. got to replace the clutch, is a recall, call maitag and verify
Posted on Oct 29, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi I have a Maytag model fav6800aww stopped in mid wash cycle,now if you try any cycle it makes a whirling noise for a few seconds then goes to the light flashing pause mode.Thanks.
No erro codes to the console correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer appears to be going throught the wash cycle but the counter is not counting down and it goes no further than the wash cycle. Just continues to do this the whole time. Model # FAV6800AWW
Here are some handy links if you are going to DIY the fix.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Are there any unbalance error codes to the LED display such as dC or uC?
When the washer stops can you place that wash load to a Spin Only Cycle and let me know if the Spin Only cycle completes. Are there any large tub swings in Spin Only cycle with that wash load that cause the Spin Cycle to stop with error codes dC or uC?
Let me know if you can to do some troubleshooting. It would require front panel removal so we can watch the Motor and verify it will rotate the Clutch Pulley CCW in the Spin Only Cycle. If you want to troubleshoot I will give you additional info to begin the process…….Rich
Apr 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Constant beeping and cycling through spin options
Did you ever get a fix to this? My machine has the same symptoms and the control board replacement did not resolve it.
Oct 11, 2009 | Maytag Washing Machines
Spin cycle locks up
it is the clutch and be repalced fairly easily
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
4,092 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
