Question about Brother MFC-9420CN All-In-One Laser Printer
Makes loud sounds
The printer makes loud, long sounds like it is trying to roll or catch paper when it starts up and when it prints. Any suggestions???
  • 3 more comments
  • Anonymous Feb 07, 2008
    I have this problem too with my Brother MFC-9420CN. It is only 8 mos. old and has a loud (grinding) sound. Like it is having a hard time getting the paper.
  • loud brother Feb 07, 2008
    My brother MFC-9420CN has that same loud noise. It is only 8 mos. old.
    The loud (grinding) sound when its trying to get the paper is terrible. Help!
    What can I do?
  • wutup Mar 07, 2008
    same problem. it is very annoying, especially when you are on the phone. i can't wait until this thing dies so i can buy an hp or epson, anything but brother.
  • hghmiami Apr 29, 2008
    Same problem here plus the piece of junk is wrinkling the paper. Checked the transfer roll, back cover and fusing unit. I purchased this machine and expect to receive a written warning pending discharge.
  • cpa1aaa Mar 29, 2009
    Brother MFC 9420CN makes tremendous noise?
    While printing a 75 page pdf, it starts out with something that sounds like little duck calls and then at about 20 pages the sound gets louder and becomes a solid sound of that same duck call frequency (if that is the right word). It's loud and it lasts about 15 seconds. Then it goes away and at about 55 sheets printed it gets sold and very very loud and disturbing again and goes back to fast duck call that sometimes gets louder. I print a lot of jobs about 100 pages, mostly tax returns. Yesterday some sheets (49 to 58) came out very light to blank and then got darger again.
    Any Ideas?
I had the same problem with the loud grinding sound. The gears on the cartridge(s) is not turning but rather stripping creating a grinding sound. Reinstall all of the toner cartridges. If that doesn't work, pull each cartridge out and manually turn the gear on the cartridge. If the problem persists, you may need to purchase a new toner cartridge.
Posted on Aug 18, 2008
There is something preventing the printer to grab the paper to keep it from printing. I have checked to make sure that nothing is inside there, and there isn't. It rolls like its going to print,...
Try to remove the sheets of paper from the feeder. If you are physically able and willing, carefully turn the printer upside down. Any foreign objects or debris that may have accidentally fallen into the feeder should just freely roll out of it. If feeder is clear, place the printer down. Open the printer cover and make sure the paper path in the cartridge area is free from obstructions. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reload some paper and try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 26, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
Paper jams after printing and will not exit top output tray
sounds like the gear drive assy faulty.take it back to where you purchased.Samsung should cover under warranty.
May 25, 2009 | Samsung ML-2510 Laser Printer
Loud Abnormal Sounds with each print job
It may be a paper feed issue. If using a duplexer, try removing the duplexing unit and try printing again. It's often attached to the back of a printer.
May 21, 2009 | Dell 3100cn Laser Printer
My paper just rolls through the printer
Happened with mine
Just send the image to the printer with it switched off
Then turn it on
Worked with mine but dont shout at me if it doesnt!!
Apr 19, 2009 | Epson CX8400 All-In-One InkJet Printer
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
MP600 not detecting the paper
The above solution is very detailed and informative. It's great. Thanks. Also, a good first step is to check the paper feed to make sure it is set to the correct loader. Sounds stupid but easily overlooked.
Dec 05, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
My New ML-2010 creates a loud annoying sound!
Ok, it is good you checked for paper jams. I need you to look inside the unit where the paper roller is on both sides and see if both sides look even and the same. It still sounds like a jam to me, and this would definitely create a loud sound as your unit is trying to print for you and the mechanism will keep trying to turn even if it can't. Something may snap or break if there is a jam so make extra extra sure you check every nook and cranny as jams can be so very tiny. I found a piece the size of a matstick width in mine that my toddler had posted in it, and it was caught in the paper roller teeth inside the unit. When you open your printer, does the cartridge holder roll by itself to the left or stay still??? Take out the toner cartridge and thoroughly clean inside with solution and replace.
Aug 16, 2007 | Samsung ML 2010 Laser Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
616 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
