Question about Dell 922 All-In-One InkJet Printer
Dell 922 "cover open" problem / error message
I have a problem with my Dell all-in-one 922 printer.It keeps bringing up the following error message: "cover open".I have opened and closed the cover several times with no sucsess.I have unpluged it but no luck.The power switch doesn't respond either.Almost like it's stuck on the error message.
  • bobhonney May 21, 2009
    Cover open message on Dell 922 Printer
  • 3 Answers
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then close the printer after it powers on.
It worked for me.
Posted on Dec 29, 2007
I know this answer is to an aged question but I just ran into this with a "cover open" error on my Dell 924 AIO (very similar to the 922 I suspect). When you open the printer to access the cartridges there is tab that sticks down from the cover just behind and to the right of where the hole is where the cartridges are located. This is for a 924, but again it is probably very similar to the 922. If not then look for a tab that trips some sort of switch when the cover is opened or closed. The fix I did will work either way. This tab is what trips a switch and tells the printer when you open and close the cover. I used some electrical tape to fix it but any tape would probably do it (electrical or the tried and true good ole duct tape would probably be the best two options).
Basically what I did was take a small piece of tape and rolled it up. I then taped this piece to the leading edge of the tab so it would trip the switch. Not sure if the switch just gets worn over time and needs to get pressed in further for it to work but this worked for me. Probably not the most eloquent of fixes, but it worked. This fix has not been "battle tested" so it may need to be tweaked some as time goes on. I'm just hoping it gets me through the unused cartridges I have left...
Also after I got the "cover open" message to go away I then got the dreaded "1203 error" message. I popped open the cartridge holders, re-seated the cartridges, and shut the printer off. I turned it back on and it made me print an alignment page. After I printed the page the printer worked again....hope it helps.
Posted on Oct 31, 2014
Dell 922 saying there is a paper jam
First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
Good luck.
Thanks for using FixYa.
Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
Error message - can not print
Try checking the little "trip switch" that is actuated when oyu close the cover. To find it, locate a small plastic tip in the cover that goes into a small hole when you close the cover. This tells the printer when the cover is opened or closed. Should be on the right or left side of the cover towards the front. The tip may have broken off OR the switch is misaligned. If the tip is there try GENTLY inserting a small screwdriver into the hole and see if that solves it. Otherwise, it is a board malfunction...
Nov 25, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 print carrier stall error message. Also, error 1200.
hope it will work
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Hope you get it to go.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 18, 2009 | Dell 922 All-In-One InkJet Printer
Error message: color cartridge missing on a Dell 922
try another cartridge. if that works then you have a bad ink cart, if not, the sensor is bad, replace the printer.
Dec 30, 2008 | Dell 922 All-In-One InkJet Printer
Dell Printer 924
I kept pressing menu, since it would not bring it up turned it off and on, it fixed itself, now it is printing.
Jul 14, 2008 | Dell 922 All-In-One InkJet Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 All-in-one printer has message on printer saying head error
can you provide the error message, depending on the error and if you want to attempt to repair it yourself? Printers are like computers these days you can almost replace it for the repair cost, but if you will provide a error code we can see what we can do.
Dec 26, 2007 | Dell 922 All-In-One InkJet Printer
Printer will not print
have you been to dells web site
Nov 08, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
837 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
