Question about Dacor MCS130 Millennia Electric Single Oven
Oven light I have 2 of these ovens from 2002.  The oven lights have begun turning on and off constantly in both of them.  I keep the fuse to the ovens off because the lights going on and off, whether the oven is in use or not, drives me crazy.
  • 3 more comments
  • ljda Jan 20, 2008
    Same exact problem in addition to at times, not being able to depress the touch pad button
  • swood94109 Aug 16, 2008
    My oven light switches on and off by itself
  • patsycakes Sep 09, 2008
    The light was stuck in the on position at first and when I depressed the light button no depression or sound occurred. Then it began going alternating on/off.
    My light switches on/off and the button for light does not depress or signal when touched.
  • jjms Jan 04, 2009
    I have never hated an oven as much as I hate these. I purchased them in 2002-3 as well. I have two of them. 6 months ago I had the flickering lt. problem. Thought it would stop after a while. It was Chinese torture and never stopped. After 5 or 6 days, called repair man who said it will cost $500 to repair, or he can just make it not work at all. So now a $2K over with no light! These ovens ****.
The touch membrane is gone. You can replace it (like i did) and wait for the next thing to go wrong. Took me 3 months for the next problem, and the membrane was $300.
Posted on Apr 03, 2009
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Erratic temperature on Viking oven
What is the complete model number of your unit?
Feb 18, 2013 | Ovens
I have a MEW6527DDS built in oven. This all happens when the oven is NOT in use: The fan goes on and off, sometimes for a second, sometimes for 10+, ALL.DAY.LONG! The 'click' sound you hear when...
Wow deffinately sounds like the control brd it sounds like a pretty good examination by somebody that is used to electric.It would be a very complicated troubleshoot over a message brd.The temp problem could be calibration issues or a bad thermistor not reading to the oven correctly.but intermittent kicking on off could be more.Maybe some programming issues usually shut the power off and back on to reset but if your turning off the breaker that would rule that out.Maybe turn of power and chek plugs and wire for loose connections.that would be a good start.
Apr 25, 2011 | Maytag MEW6527DDS Electric Single Oven
Kenmore electric oven light will not turn off.
the internal pressure switch is stuck in position. its due to surface gunk build up. carmelization of oven debris.
Feb 14, 2009 | Ovens
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Oven light
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Aug 11, 2008 | Dacor MCS130 Millennia Electric Single...
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Dacor MCS130 Millennia Electric Single Oven Logo
281 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
Are you a Dacor Oven Expert? Answer questions, earn points and help others
