Question about HP Photosmart 635 Digital Camera
Battery Life My HP Photosmart 635 Digital camera has never operated properly since I got it. The problem is battery life. When I install new alkaline batteries or fully charged nicads, the batties die after 5 minutes wether the camera is on or off. I now use it as a paper weight.
  • jumpy0 Jan 20, 2009
    I have the same problem. The camera worked fine for a few months, but now it immediately turns off anytime I turn it on, claiming the battery is low. I've used several pairs of new batteries to no effect. I wonder if it's caused by the date and time battery and want to remove it. I'm using a HP Photosmart Mz67 which is configured a bit differently from the 635. Any help in locating the removing the date/time battery on this model would be appreciated.
  • 38 Answers
This is a typical problem with these cameras. The culprit is a failed onboard battery. The battery is for retaining the time and date while replacing the removable batteries. If you put batteries in and set the time and date- then remove the batteries for about 30 seconds- put the batteries back in- if it asks you to set the time and date again the onboard battery is no good. If you remove the onboard battery your camera will be very usable and the batteries will last 100 times longer. If you can change the batteries quickly you will not have to set the time and date because there is a small capacitor that will retain a charge, in other words it works better without the battery. I have done this to about 15 of these cameras and all worked great afterwards. You will need a precision philips screwdriver to remove the 7 screws that hold the case together. The onboard battery is small, like a hearing aid battery, mounted on the lower board just behind a piece of brownish cellophane like material. Just cut the material open and look in there between the boards and you will see it. It is mounted flat grap it with some precision long nose pliers or tweezers, wiggle it until the solder joints fail and remove it. Re-assemble and your paperweight is a camera again. If you do it wrong ,which is unlikely, you still have a functioning paperweight.
Posted on Jan 15, 2008
  • Gliderrider Aug 30, 2010
    Once you have opened the camera, the battery is NOT on the top of the of the camera (that is a micro switch.) The battery can be seen if you look from the side of the camera.
  • tucashow2001 Jan 27, 2011
    @Nspektor : great solution , i also have a 635 hp same problem whit bateries/acumulators ...i remove internal batery and work great now ...thanks for solution....
I have the same camera, had same problems
Replace batteries with AA 1.2 V 2600 mAh and your camera should work perfect. Mine does finally .
Posted on Mar 27, 2008
I also had battery problems with my HP PHOTOSMART 635 When I purchased the camera it came with AA batteries 2000mA .They did not hold charge even when camera was not used. Then I was talked into buying other batteries AA 2200mA. These were a bit better but still needed to be recharged more often than I thought they should be. After these gave up I wanted to get new ones again because I had an extended warranty on them ,but they did not have any more. Then I noticed on the bottom of the camera it said 2500mA . I questioned the clerk why they would give me weaker batteries than the ones that were called for. Anyway I exchanged them for AA 1.2v 2600 mAh and the camera works perfect
Camera won't stay on with new batteries
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) should not be used. hey have limited power and can leak in a short time, destroying a camera.
Feb 05, 2014 | HP Photosmart 735 Digital Camera
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Choosing batteries
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Choosing Batteries
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Battery life expectancy
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times. Olympus recommends the use of CR-3V litium battery packs or NiMH rechargeable batteries. Do not use alkaline batteries unless it is absolutely necessary.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus CR-V3 long-life lithium batteries (LB-01) will provide approximately 500 shots. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
HP Photosmart 635 Digital Camera Logo
179 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
