Question about Refrigerators
Broken door hinge
Who do I call to repair a door hinge on a kolepack walk in/reach in unit?
  • 76 Answers
Your local refrigeration engineer should be able to do this.
Posted on Dec 04, 2007
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
I have an Indesit DV62WHUK dishwasher and the last night the door made a banging sound when it was opened and now it won't close and will fall back under it's own weight. I suspect either a spring, spring...
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Dec 02, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Press heater zone buttons, doesn't change areas. doesn't open and closevent blocks
There are tubes connected to the back of the control unit that go to door actuators. Get a cheep had vacuum pump and hook it to each actuator and see if each door opens and the diaphragms inside are not leaking if they all work replace the control unit. If the doors have broken off and are laying in the bottom of the heating unit you need to replace the whole unit under dash. On extreme 4x4 or the show trucks they had a repair kit for dodge and chevy. The doors open and close just like a cheep plastic tool box with no hinges just a piece of thin plastic that bends back and forth till it breaks. The kit comes with metal hinges and new doors
Oct 29, 2010 | 1989 Dodge D150
Good Afternoon! I've got an old sandwich top two-door with a broken hinge on the left door. The name-plate reads "Superior Products" but it obviously a Bev-Air manufactured unit. Currently, True is making...
Hello there:- on all the Hinges they 've a MFG name and a Number. if you can look at it on the back side of the broken hinge . Then you can get it from any refrigeration co. or any appliance co. too. try that . Hope this can help. God Bless.
Oct 08, 2010 | Beverage-Air Refrigerators
The plastic/ rubber door hinge is broken and the driver side door will open wider than it should. How do I remove the interior door panel and replace the rubber door hinge part.
Hello. Please let me assist you.
Your door has a broken 'door check', the metal box that holds the door check has a broken weld.
What I would do if I were you:
Take your vehicle to your local Toyota dealership.
Toyota is aware of this issue, and has issued a repair procedure.
Toyota will repair the vehicle at NO COST to you.
Thanks for using FixYa!
Feb 07, 2010 | 2001 Toyota Sienna
The water is leaking out of the door
The seal around the doors is broken. Is there anything keeping the door from closing right? Has there been any damage to the door ?(somebody walking in it damaging the hinges?)
Dec 06, 2009 | Washing Machines
Dacor microwave model DCM24s broken door latches
Many times restaurant supply houses can have what you are looking for in terms of hinges. However, when the hinges, seals, megatron tubes go....generally its time to go shopping for a new unit!
Nov 09, 2009 | Dacor DCM24SS Convection Microwave Oven
Door falls clear to bottom when opened almost got foot broken it was repaired by sears 2 years ago now broke again Elite mod=665 16982201 ser=fp2401121
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Aug 26, 2009 | Dishwashers
LG Microwave Countertop Microwave Oven LRM2060 ST. The glass on the outside of the microwave door is broken. Can you order just the glass from somewhere and can I fix it myself?
Due to the serious potential for RF leakage, these doors are normally sold as a complete unit assembled by the manufacturer. I could only find the door listed at for about $80. If you wish to repair yourself, the old door comes off by opening it all the way and lifting straight up at the hinges. The door will then lift off the hinge pins. Reinstall the door new door by aligning it with the hinge pins and allow it to seat straight down. A simple repair.
If you have any questions about this repair, or require addtional assistance, please let me know. I hope this helps you.
Aug 11, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Refrigerators Logo
226 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
