Question about HP Officejet 5510 All-In-One Thermal Printer
Feeder problem The feeder just suddenly stopped working properly. A page will begin feeding through and then starts to go crooked - the page gets jammed.
  • Paulcpnm Jun 02, 2008
    My HP Officejet 5510 feeder stopped working correctly. The gears turn but from what I can tell, they are turning the wrong way. The rubber guide that pulls the paper only engages if it turns one way. It is turning the wrong way and thus not engaging.
    Scholar:
  • 139 Answers
Posibilities r ink,rollers,catridge head etc so loos n check these things if there iun place
Posted on May 26, 2008
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
A new welding machines lincoln 500s with wire feeder linc feed 45 co2 gas shielding ... when i begin the welding process continueous just for 10 seconds and then the wire feeder stop and then after 50
the obvious, yet sometimes overlooked problem is to check if the wire feeder rollers.do you have the proper tension set?(did you do the wire test when you shot the wire to see if it bends or stops)
Apr 11, 2013 | Lincoln Electric Welding Tools
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP 7410 Paper Feeds in Crooked
The paper size in the feeder and the paper size in your printing properties have to match.
I.e. if your printing format says "letter size" and in your feeder is legal or A4 paper you will get this error.
Please reply if this does not help.
Dec 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Document feeder
Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
Oct 25, 2008 | Office Equipment & Supplies
Auto-Feeder Does not feed paper evenly
There must be a small jam in the feeder. You can try sliding a business card or heavier plastic card through the feeder all the way across. Chances are it will push whatever is stuck in there out.
Jul 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Sheet feeder isn't working
which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
Jun 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP Officejet 5510 All-In-One Thermal Printer Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
