Question about IOGear GCS632U 2-port KVM Switch
IOGear 2-port KVM Switch (Keyboard Issue)
I have ten 2-port kvms. After a week or two the keyboard stopped on one. Checked the connections, changed the keyboard and disconnected the kvm and started all over with no luck. After a few lucky kicks and punches it started working (not sure if it was the kick or punch). A week or so later........I have two more machines with the same issues. How would you approuch this problem.
  • MattM100 May 20, 2008
    I have the exact same problem. I'm using one 2-port KVM switch - it was working fine for a couple of months. I just plugged in an external hard drive (USB) and the keyboard stopped working. But, if I switch the mouse and keyboard USB input into the KVM switch, the mouse won't work. So it seems that one of the USB inputs is bad.
    By the way, I can't switch to my other computer no matter which side I plug the keyboard into (on the KVM switch.)
  • Anonymous Mar 05, 2009
    Same problem, Running vista..
    sometimes the keyboard works other times it does not.
I have had the same problem off and on since I bought my Iogear 2-port kvm switch over a year ago. I have a DYNEX wired, multimedia, usb keyboard and a Dynex wired usb mouse. The operating system on my desktop is Windows XP, SP3 and on my laptop it's Windows XP professional.
Yesterday, my keyboard "died" on me about 8 times and each time it requires unplugging the keyboard usb cable from the switch and my laptop, rebooting, then plugging the usbs back in. Really, really frustrating and annoying. I'm not a techno guru, but I got to thinking that maybe the keyboard driver might be the culprit. I decided to go to Control Panel, clicked on Keyboard, then Hardware/Properties/Driver/Update Driver. I clicked on "update driver" and let it find one automatically. It took what seemed like a long time for it to find the driver but it found one. The device name changed to KeyMaestro P2360, the driver updated, and I noticed 2 additional files were added to the System 32 directory.
It's only been a day but so far so good. My keyboard hasn't failed yet since the keyboard driver update. I don't know if this is the solution for you or not, but it seems to be the one for me. I'll know for sure if I can through a few days without it failing again.
Posted on Nov 12, 2008
Check the serial ports ???
What are you working on an old DEC mainframe ?
Posted on Dec 13, 2007
  • 42 Answers
Check serial port connects, turn the screws in, check port board for cracks, if the cables are getting pulled or tugged, and have ya ever spill softdrinks/coffee on the switch?
Posted on Dec 09, 2007
I have an IOGear GCS1734 KVM switch and two Windows based machines. I work for the gov't and we have to use a CAC Card. My keyboard has a slot/reader for my CAC card to verify my credentials. If I...
As far as mouse is concerned all you need is PRACTICE, and there may be a compatibility issue with your keyboard or the wire you are using is not fine, coz the kvm switch is definitely ok when used with 2 systems.
Oct 19, 2010 | IOGear USB gcs1734 4-port KVM Switch
This worked great for a couple of months and now
It may be possible that the KVM has gone bad. Make sure the keyboard is plugged into the keyboard port of the KVM as this is the only port on the KVM that will recognize the hot key commands. If you have ensured the keyboard is plugged into the keyboard port and you have tried multiple keyboard and still experience problems I would assume the KVM is having problems. IOGear KVMs have a three year warranty and their support can be reached by email support@iogear.com.
Jul 26, 2010 | IOGear GCS634U KVM Switch
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
I just purchased an iogear GCS1742 2 port kvm Switch. The keyboard is the only piece of hardware that will not work. I have two cpu systems and one monitor. The keyboard has a PS2 connector with a usb...
Bill,
Due to the keyboard emulation that the GCS1742 uses it may not work with a PS/2 to USB adapter. If possible try using the KVM with a basic USB wired keyboard. This will tell you if the KVM is in working condition or if there is a problem with the actual KVM. If the KVM does not function correctly with a basic USB wired keyboard then I would think there is a problem with the KVM.
May 20, 2010 | IOGear GCS1742 2-port KVM Switch
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
Not switching systems
Make sure your keyboard is plugged into the keyboard port of the KVM. The IOGear KVMs use a keyboard and mouse emulation. Due to this the keyboard port is the only port will recognize the Scroll Lock command.
Oct 12, 2009 | IOGear Computers & Internet
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
I have an iogear usb kva switch connected to two PCs (one desktop; one laptop). It used to work fine with a wireless keyboard (HP), but after I replaced it, it stopped allowing me to switch between PCs...
Hi ther. make sure that you connect them to the correct port. If using a wireless keyboard, connect the receiver to the keyboard port. check underneath for the keyboard icon. Make sure that the receiver is connected to that port.
May 09, 2009 | IOGear GCS632U 2-port KVM Switch
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
1,626 people viewed this question
Top IOGear Computers & Internet Experts
castletech
castletech
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
