Is it possible to get a a circuit diagram for a Servis caress 900 'A' washing machine please?
The belt has snapped, removing some of the wires and I am unable to repair it without a diagram/photo of the wiring.
The company appear to have shutdown as non of their phone line, email, or website are working.
Thank you for your patience. I have searched thoroughly and unfortunately have been unable to locate a wiring diagram anywhere that falls under the numbers you found on the machine. I'm sure sorry and will continue looking, but it's like the wiring diagram/tech sheet for the unit you have is a state secret or something. LOL Again, my apologies and best wishes and I hope that you will utilize Fixya again in the future with better results. Thanks again.
Their is usually a wireing scmetac inside the timer and switch housing of most machines.
It is a front loading machine. There is a sticker behind the door with this number: 20012516527 010203011 01 01
and next line: M3009A
There is also a this number molded into plastic inside the machine (probably the plastic-molding part no.):
Fontalino AP 1M 2P
110291100
hope that is of some use!?
Thanks, J.
unfortunately not on this machine
Thanks for the help. I noticed that some of the wires have small labels on, corresponding to the pins of various components, so managed to reassemble most this wiring - all except that to the thermostat, but have since discovered that the motor is burnt out - The machine is beyond economic repair so please don't waste any more time on this.
Thanks again,
j.
I will need a more complete model number to try and assist you. On top load machines the number is usually located either under the lid, on the back of the control panel, or on the lower front or side of the main cabinet body. On front load washers the model number can usually be found either behind the door, behind or on top of the control panel, or on the side of the unit near the front. See if you can find a more complete model number by looking in these places and let me know what you find. If you can find me a model number, I will do what I can to assist you. Thank you and best wishes.
