I'm assuming this is a microwave unit. Never run the machine without a load--cup of coffee, any kind of food or beverage, but never use any kind of metal object. No-load or metal within the cavity can cause the microwaves to arc, burn local areas, or kill the magnetron output due to overload. Unplug the cord, then open the case. Short out the high voltage capacitor (a can with two terminals standing up) with a screwdriver for safety. The magnetron sits on a sort of pedestal and has fins to get rid of heat. A sheet metal channel (called a wave guide) runs from there over to the cavity. Just over or beside where the microwave energy enters, there is inside the wave guide a metal fan-like device called a 'stirrer'. The stirrer scatters the energy so there are no 'hot spots' in the cavity. The stirrer also has a plastic bearing that the microwaves can sometimes arc through and short out the energy thus blowing a fuse. Anyway, remove the waveguide and look under it from end to end for any scraps of metal, wire, or other stray material. This area must have only the stirrer in it. Check the stirrer, spin it to see if it wobbles up and down (it should not) and if the bearing is clean. Check the magnetron that it is mounted tightly. Reassemble everything and test the machine. I hope this helps>
How can I check the thermal switch on my GE Profile Microwave?. Where is it located and how can I...
(More)
How can I check the thermal switch on my GE Profile Microwave?. Where is it located and how can I get to it?
The surface light on my GE microwave oven has a high and low setting. The low setting no longer...
(More)
The surface light on my GE microwave oven has a high and low setting. The low setting no longer works. I purchased new halogen bulbs and they worked for about an hour. Now the light does not work on the low setting. The lights work on the high setting only. What could be the probelm.
tray doesn't always rotate. sometimes yes, sometimes no .GE advantium model sca2000fww03 If we take...
(More)
tray doesn't always rotate. sometimes yes, sometimes no .GE advantium model sca2000fww03 If we take the food out and run the micro empty for a little bit, and turn on the oven light to see what's happening, we find that in a few minutes it decides to start turning. Most of the time.
Hi, I picked up a used 2000 Chevy blazer for my daughter, 4 door and it needs speakers bad. I...
(More)
Hi, I picked up a used 2000 Chevy blazer for my daughter, 4 door and it needs speakers bad. I believe their are 6 total, 2 on the dash and 2 in each door. I have been trying to find info at the library and online as to how to replace them. The dash speakers look like they are replaceable from the top of the dash by removing a coule screws. The doors I am not sure if the speaker covers just pop off or if I need to remove the inside panel of each door. Any help is appreciated, including sizes that fit. Thanks in advance. Dennis
