The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
If you have downloaded the Windows 8 Pro setup, then launch it and follow the instructions, when promted for the key, type it in. If you have got a psyhical DVD from Microsoft with Windows 8 Pro setup.exe, insert the DVD in, when promted write in the key. Could you please give me more info. about the problem itslelf?
You need to configure the router manually because teh CD wont work properly.
>Open Internet Explorer and in the address bar type 192.168.2.1.
>You will be in the router setup page.
>Check if the internet status is connected on the right hanh side of the screen is yes continue with the following steps.
Step 1: Select channel and SSID and changed the channel to 11 and changed the SSID to a 8 or more letter work without space or special characters and then click on apply changes.
Step 2 :Then select Wi-Fi protect setup and changed it to disable and click on apply changes.
Step 3 :Then select security and changed it to WPA/WPA2 type and entere a password in password (PSK)/Pre-Shared key (PSK) box with not less than 8 characters--(Its case sensitive) and then click on apply changes
Step 4 :Try to connect wireless on the laptops and enter the security key that you enabled and click on connnect.
Step 5 :You will get a message "Connected' and you will be able to go online If not give Belkin a call 1800-223-5546
If it is the proper product key and it won't work that is a problem Microsoft will gladly solve for you without charge. Go to your Microsoft.com website and let them know what's happening and they will give you another product key or let you download a new setup. Good luck!
