Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
No display i have big problem with my pc. i use motherboard gygabyte 8vm533-rz,ddrram 1 gb, and processor intel p4. why that cpu that load display (no display) but the other working like cd room, led power etc.please help how to fix my problem,,,,i has try to change processor and ddrram but nothing working,,it,s the same time,,,,no display at my monitor,,,,pls help me
  • mahapatra Jan 05, 2008
    cpu &ram changed & cpu is heat
  • Clarence20 Feb 11, 2008
    hi I have same problem to encounter to this board kindly give us accurate support solution for this issue.
    I try all configurations and troubleshoot the board is nothing change there no video out.
I have facing a same problem also..
noting is showing but i cant enter until window starting sound.
on & off monitor still the same no image.
how..... please help....
Posted on Jun 01, 2010
    President:
  • 2,351 Answers
First things first. Please make sure you monitor is correctly connected to the video card and tight. Do not over tighten the video cable. The CPU does not load the display directly. The video card does. Be sure the card is seated. Remove and re-seat the video card. You can also go to Gugabyte and check the FAQ section for similar problem you are having at:
http://www.gigabyte.com.tw/Support/Motherboard/FAQ_List.aspx
Posted on Dec 04, 2007
    President:
  • 4,402 Answers
Try a video card and turn off the onboard display card.
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
I have an old IBM Netvista 6794 pc with its original IBM motherboard that it came with P4 pc with a 2.0ghz cpu. Now I want to change the processor. My question is can a 3.6ghz or 3.4ghz p4 intel cpu work...
Unlikely, I would think that the best processor you could use would be a 3.0Ghz or maybe a 3.06Ghz. If you look at the motherboard part number you will be able to find out from the manufacturers what the fastest CPU is. A lot depends on the FSB on the mobo and the Bios version. You need a "Socket 478" processor I think you will find that the processors you are looking at are "Socket 775" ( this is the fitting socket for the processor) .
Feb 11, 2012 | Intel Computers & Internet
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Msi p4n sli board
The Only CPU's that board supports are:
  • Supports 90nm LGA775 processor package
  • Supports Intel Pentium Processor Extreme Edition
  • Supports Intel Pentium D Smithfield processors
  • Supports Intel Pentium 4 / Pentium 4 Extreme Edition processors
  • Intel Hyper-Threading Technology ready
  • So sadly no I am sorry. However it does Support a P4 with HT which is still a very nice CPU
    Jan 15, 2009 | MSI P4N Diamond nVIDIA nForce4 SLI LGA775...
    Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
    MSI has two boards P4M900M3-F, P4M900M3-L.
    Both of this will support your CPU
    Nov 26, 2008 | MSI Computers & Internet
    Installing P4 2.8ghz cpu
    That particular motherboard only supports AMD processors:
    http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=1764
    You will need a new motherboard to use your Intel 2.8ghz chip.
    May 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
    P4 ugrade required
    Sadly you wont find any 1066Mhz FSB processors for the Socket 478. The best you can find is the 3.4Ghz with 800Mhz FSB. It might be cheaper and also better value for you to get a Socket 775 based motherboard and Core2 Duo processor. The value range E2160/2180 processors or the E4300/4400 processors have been tested to be even faster than the Socket 775 Pentium Dual 3.4Ghz and they also use less power.
    An article on socket 478 for you http://www.xbitlabs.com/news/cpu/display/20040123103754.html
    Dec 02, 2007 | Intel P4 Socket-478 Original CPU Cooling...
    Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
    156 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Alun Cox
    Gbenga
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
