Question about Epson Stylus Photo R200 InkJet Printer
PRINTING WRONG COLOURS
PRINTER IS PRINTING TEXT REDDISH/BROWN  INSTEAD BLUE AND GRAPHICS ARE A VERY MUDDY, MISERABLE MESS.
NOZZLES HAVE BEEN CLEANED.
  • TRUMP Dec 05, 2007
    Good advice!  The problem I think was that 3 of them were over 6 months old.
    President:
  • 4,402 Answers
Have you replaced the injects? and were they refills or originals? and are they in the correct slot?
Posted on Dec 04, 2007
Why won't my printer print purple?
Your Cannon printer is not the problem. You will get different print color depending on the paper you are using, For example you will get different print result if you print on color paper than on white paper and a different print if you print on photo paper. Another alternative is to lighten the tone of your purple. I don't know what your objective is and what project you're working on but I hope this might help.
Apr 26, 2014 | Canon MG5150 AllInOne Printer
The blue color is not printing correctly. It comes out sort of pink and greens are yellow. I have a new balck drum. I have put in a new blue toner cartridge. I have tried adjusting color saturation. ...
create a doccument with four identical lines of text.
the text should be as follows:
your text in the colour Black, the cyan, then yellow then magentta
see if they print in the colours you used, if they are all wrong then delete all drivers associated with the printer and delete the printer, then follow the install proceedure again to reinstall, if just one colour is wrong the it is most likely a deffective cartridge.
Dec 06, 2013 | OKI C5100n Laser Printer
Our printer is so unreliable. you can never print anything without either the colours printing wrong ir lines appear across the image. I have repeatedly tried cleaning the nozzles and deap cleaning but it...
  1. Lift the document cover to expose the platen glass.
  2. Wipe the platen glass (A), white areas (B), and transparent sheet (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 20, 2010 | Canon I900D InkJet Photo Printer
After replacing cartridge in dell 810 the colours printing wrong
Hi
If you haven´t used your inkjet printer for a while it may just be dry ink clogging some of the nozzles in the print head.
To check if yours is clogged...
Remove the ink cartridges
Holding the cartridge upright and press down gently onto a paper towel.
The colour cartridge
you should see YELLOW, MAGENTA (red) and CYAN (blue)
But if any colours are missing? The inks have probably just clogged up? and you will need to buy a new one or if you know you still have ink then you can easily unclog it with a
Magic Inkjet Flush Kit (Which you can find on Ebay)
MIXED COLOURS
If you have others colours coming out then the colours have mixed...
Sometimes caused when people put tape onto the inks to keep them moist but instead the colours mix through capilary action.
If so... leave print head sitting on a paper towel for a few mins until the correct colours appear.
Read more about ink clogs here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
To prevent an ink clog it is best if you print something regularly about every 10 days to keep the tiny print head nozzles / jets open. Otherwise the ink in the print head will thicken. Then it´s like trying to pass a camel through the eye of a needle.
So to preven inkjet ink from clogging print something every 10 days if you dont have anything to print, use something like these test prints
PRINT TEST SHEETS FOR USE WITHMagic Inkjet Flush
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Good Luck!
Hope this helps you!
Tinteiros (Ebay)
Oct 28, 2009 | Dell 810 All-In-One InkJet Printer
Not printing out true colors
My guess is you either have the wrong cartridges or your cartridges need replacing.
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
Colours are not true, grey is brown
You are getting leakage from one color cartridge to another. Do deep cleaning and run nozzle check. You may have been using non-Cannon inks. They can corrode the ink cartridge seats due to inferrior quality ink. You may need to replace the print head. Check out Cannon web site under this printer support. Print head is in the $50 neighborhood.
Feb 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Colours are wrong
Most likely a toner spill down the back side of the carousel. Remove all the toner and dev unit and vac out any spillage from within the printer. DO NOT VAC THE DEV OR TONER UNITS.
Replace all the units and print about 200 full colour pictures (preferably a test chart - Gretag McBeth or similar) at full size (A4). See if the colour then begins to return to normal. If not, you will probably have to replace the dev units too.
Oct 24, 2008 | Epson Aculaser C1100 Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
128 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
