Question about Kenmore 54501 Dehumidifier
Dehumidifier shuts off after 2 mins
I have a 54501 Kenmore Dehumidifier and the unit operates properly for approximatemly 2 mins , with thye fan on, then shuts off with all lights and setting remaining in their origonal settings. If I turn the unit off then back on it turns on again for another 2 mins then shuts down again.
  • loganrun Jul 08, 2008
    Same problem. If I turn the knob to off then back on, it will run for another 1-2 minutes then shut off.
  • cmlee Jul 18, 2008
    I have the same problem: shuts off after 2 minutes. Also the Humidity Cnntrol setting is not working properly. Am unable to change the value above or below 70%.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
You might have a compressor problem, in which it won't be economical to repair. if you are using the unit in cold weather then it just might be that there is not enough humidity in the air and it is cycling fast.
Posted on Dec 19, 2007
Does the fan on a Kenmore dehumidifier run continuously, or does it shut off when the set point is reached? I returned a Frigidaire unit because the fan is designed to run continuously.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Kenmore 54501 Dehumidifier
Re: Kenmore 54501 dehumidifier. Both fan and compressor sound as though they are turning on, but no water is evaporated into the water bucket. The unit had always operated properly during past seasons,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 24, 2011 | Kenmore 54501 Dehumidifier
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Sep 01, 2009 | LG DH30 GoldStar Dehumidifier
Fan does not operate in my 54501 Kenmore dehumidifier; therefore, unit gets very hot.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 11, 2009 | Kenmore 54501 Dehumidifier
Kenmore Dehumidifier Model 580.52650 Says "Bucket Full" - Wrong
the problem is with the switch which is connected to the float arm, try pulling it manually, it shoud turn on and off your unit if working properly
Jun 14, 2009 | Kenmore 54501 Dehumidifier
Kenmore 54501
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
May 28, 2009 | Kenmore 54501 Dehumidifier
01% humidity
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Problem
Jul 17, 2008 | Kenmore 54501 Dehumidifier
Kenmore 54501 Dehumidifier Logo
636 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
