RCA HD50LPW166 Replaced lamp and now color is all blue and green no red at all.
    Genius:
  • 1,030 Answers
Was color normal before
color is generated on dlp by a device called a color wheel...when you start it up does is sound like a motor running
Posted on Dec 07, 2007
Weeeeeeeeee
Posted on Feb 01, 2008
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
The screen is green no color at all it makes aloud humming sound what is the problem we replaced the lamp last year
Do you have a cable box going to the TV and is this condition on all of the inputs or just one. Chances are you have standard video connection plugged into the component inputs.
If you have a (yellow/red/white) cable make sure you have it plugged into a connection on the tv that matches those colors because if you have a standard video (yellow) plugged into the Green then you will get a black and white picture.
If you are plugged into a component connection you will need a total of 5 RCA style wires. One will go from Green to Green, another from Blue to Blue, another from Red video to Red video, anther Red audio to Red audio and white audio to white audio.
The common mistakes made with this connection is the reversal of the RED video and RED audio which will cause the humming noise you spoke of as well.
Thanks,
Robert
Mar 01, 2011 | Hitachi 60V500 60" Rear Projection...
Loud humming noise while rca Mod hd50lpw166 is running
There is a excellent chance it is the Color Wheel in the Optical Block. Some of the older models are not too bad to replace it, on the newer one though it is a major tear down. I would have a RCA Servicer come out to verify and get a estimate. Chances are do to the cost of Optical Block, it would be close to replacement of the Set.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
Replaced parts--here's where we/re at
Check all tubes Red ,Green look for crack or broke some even leak fluid out on board.
Aug 29, 2008 | RCA D52W19 52" Rear Projection Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Low intenstity on green lamp
sounds like the Green CRT need to be replaced. Thats fairly common with your model with that symptom. If you need a link to where you might be able to get a replacemeny let me know.
Jun 07, 2008 | RCA P52955 52" Rear Projection Television
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Mar 07, 2008 | RCA P61940 61" Rear Projection Television
Color
what lamp did you replace?
Dec 04, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
353 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
