FixYa.com
Tags:
Bosch HDI7152 Stainless Steel Dual Fuel  Kitchen Range
Installing the Bosch HDI7152 slide in with a bull...
posted by Ah Ha on Dec 04, 2007
my counter has a bull nose front and the slide in range does not look finished against the counter. What do other installers do when installing the Bosch slide in into a counter with a bull nose front?
Comment by Ah Ha, posted on Dec 04, 2007
let me know if this pic is good enough to understand what I was trying to say
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Freer
Rank:Master Master
Rating: 86%, 37 votes
I need to see a picture of the condition you are talking about before I make a suggestion.
Comment by Freer, posted on Dec 06, 2007
The pic of the bull nose detail didn't come through, but I have some suggestions anyway. First of all, The way Bosch finished the control panel ends is strange. No matter what you do, the fix may not completely satisfy.
1. You can cut off the awkward triangle flange and file the edges smooth. Do this only if it won't expose any openings or weird detail. 2. If the triangle flange prevents you from pushing the range into position against the wall, you could cut away the bull-nosing just in the areas where the triangle flange is, and smooth any sharp corners. 3. If the range is all ready to the back wall and the control panel sticks out from the bull nosing, you could fabricate  filler pieces the had the contours of the bull nose on one end and the contour of the triangle flange on the other. This piece would be applied to the sides of the range. 4. If you take a look at your instruction manual, you will see that it covers both the stand alone model and the slide-in. You may like the flat control panel on the front of the stand-alone version. If you do, and the bull nose issue is really getting to you, you may want to have the stand alone front panel fitted to your range, if possible.
No matter what you do, there is no easy fix.
Rating Locked! (?) Ah Ha has rated this solution as Helpful
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
My stove temperature is...
My stove temperature is... Answer This...
Kitchen Ranges
Can I still get an
Can I still get an instruction... Answer This...
Kitchen Ranges
fault code f2 maytag model
fault code f2 maytag model num... Answer This...
Kitchen Ranges
New Kitchenaid Architect 6...
New Kitchenaid Architect 6... Answer This...
Bosch HDI7152 Stainless Steel Dual Fuel...
Bosch Range Flashing Symbol
Hi, I have a Bosch Dual Fuel... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
