Question about HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210
I have no power to unit won't turn or flash blink nothing. Any Ideas?
    President:
  • 2,351 Answers
1.) Double check the power outlet that your printer is pluged into. Swap to another outlet. 2.) Double check the plug at the printer end, it may go in only one way. Still no power when you press the power button? It may be bad. Return it.
Posted on Dec 04, 2007
Hp psc 2210 all-in-one on power up all the lights blink nothing else happens
connect the printer directly to walloutlet.disconnect the power chord from the back of the printer press the on button on the printer for 10 times.then press the power and cancel button simultaneously and keep holding the buttons while with the other hand disconnect the power chord wait for a minute connect the power chord back to the printer .if that does not work then took out all the cartridges clean the electrical contacts on the cartridges also clean the electrical contacts in the printer then put the cartridges back .if that does not resolve the issue try with new set of cartridges.
Sep 13, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dead PSC 2210 - can't get print cartridges out!
Try connecting the printer directly to wall instead of surge protector and see if tha resolve the issue
Aug 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 the machine is overheat and won't go
I will tell you my friend to replace the formatter board and do service the mechanism.
Jul 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 won't initialise
Unplug the power cord from the All-In-One and also from the wall outlet,
Leave the cable unplugged for atleast 1Min.
Connect the cable directly to wall outlet without the surg protector and before connecting it to the All-In-One press and hold the # and no 6 Button and plug the cord to the unit without releasing the keys, it should come up with the message as Semifull Reset
If the display goes off or printer turns off then release the keys and turn the power on.
Good Luck.
Aug 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210
hai
the printer NVRAM was became bad. so you have to contact you hp customer care
Jul 31, 2008 | HP PSC 2210 All-In-One InkJet Printer
Photo card inserted backwards error
Try a full NVM reset on the unit and check
Reset Steps are.
Unplug the power cord from the unit when there is still power in the All-In-One and press and hold the # and No 9 Button without releasing the buttons plugg the power cable back, it should come up with a message as reset
If the screen go's blank after you connect power cable, then release the keys and turn the power On, it will come up with a message as Full NVM Reset
Good Luck
May 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all in one
i have  a imac and a hp 2210 all-in-one printer. When i print nothing happens.  the box that pops showing the printing jobs says that it is printing, but then it stops the jobs
Dec 29, 2007 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210
The bulb in your HP PSC remains on for a specified period so that the unit
is immediately ready to respond to your request. When the HP PSC has not
been used within that specified period, it turns the bulb off to preserve
power and displays Power Save On in the front-panel display. (You can exit
this mode by pressing any button on the front panel.)
Your unit is automatically set to enter power-save mode after 12 hours.
Follow these steps if you want the HP PSC to enter this mode earlier.
1 Press Setup.
2 Press 5, then press 6.
This selects Maintenance, and then selects Power Save Mode Time.
3 Press until the desired time appears, then press Enter.
http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Nov 10, 2007 | HP PSC 2210 All-In-One InkJet Printer
Problems
Switch the unit. let it rest for half an hour. While it is resting check the manual for any 'faults' list. Look for a 'reset' command - may be mean pressing several buttons while the machine is off and then with the buttons still pressed switch on the machine[you may need two hands and a nose or three hands for this ;-)] If still out of luck go to places for further info HP technical support team or www,fixyourownprinter.com
Jul 05, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
