Question about GE 24 in. GSD5940 Built-in Dishwasher
Ge dw gsd5940
Hi this dw just started leaving water (1" or so) in the bottom of the unit. We cleaned out the basket looking item toward the back and the hoses don't look kinked, it runs through cycles as normal and sounds fine. Any suggestions as to what to look for? thank you.
There is a piston nut in the back under that screen,.... check into replacing it.
Posted on Apr 14, 2008
Skipping cycle
I think that # 4 is the solution to your problem. Something isn't right with the world, the DW is thinking. The sticking float seems like the problem here. If not, consult the owners manual on the error message you receive if any.
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 11, 2014 | Bosch Dishwashers
The machine does not fill with water, pump start to work as soon as you switch machine on.
The item number 4 is for your problem. I think that the Float is stuck.
Good luck.
Jan 11, 2014 | Dishwashers
GE dishwasher is not draining
Good luck. Hopefully this helps.
Jan 07, 2014 | Dishwashers
GE model GSD3200GOOWW Serial # MD71074513
Good luck. Some times these simple steps will work.
Nov 18, 2013 | Dishwashers
Hi I have had this intake/drain light come on in my Miele G851 SC dishwasher. I followed the recommended instructions in the manual: - clean triple filter, drain pump, and non return valve - check...
Is their debris in air gap or in the bottom of the DW, where the drain is screened? Look for obstructions.
Good luck.
Oct 25, 2013 | Miele Dishwashers
Not cleaning silverware and leaving film on dishes
to much detergant or not enough hot water prime sink before starting dw
Jul 01, 2010 | GE 24 in. Profile PDW8280JSS Built-in...
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
LG LDF8812 Diswasher - Self Cleaning Filter not cleaning itself
you should not have to use any type of screwdriver to remove filter. The rest of it , leave alone. Take both rotors out and run unit. Both rotors top and bottom should push water through at a good rate. If not, a blockage in water /motor line. I suspect the rotors simply need to be properly cleaned, If not rotating properly it will cause undesolved residue.
Mar 28, 2009 | LG LDF8812 Stainless Steel Built-in...
Dishes not getting clean, left with gritty residue. Could the filter be backed; if so how do I fix it?
Had the same problem with a GE Nautilus 3400 series.
Solution:
- In their manual, GE recommends not stacking tall dishes on the bottom right tray - this prevents the dishwashing powder from fully dissolving. Are you using the right detergent and rinse-agent ?
If your upper arm is not turning during wash (DW leaves residue on top-shelf items), do the following:
1) Empty the DW.
2) Pull down the rotating arm on the DW ceiling. Thoroughly clean the passageways (I had to tap it on the counter to break-down the sediments).
3) Inspect the mesh-screen filter located on the floor in the back - if it's backed up (ours was backed-up from the inside), you'll need to clean it by removing 4, 1/4" screws holding it to the DW floor and throughly cleaning it (I also unscrewed the plastic valve located on the bottom of the filter compartment). While you're at it, remove the plastic mesh on the DW floor (2 screws) and fish for any objects and sediments blocking the pump.
4) Replace filter and bottom mesh and operate the DW in "Rinse" mode.
5) Press the rotating arm back in and operate the DW in "Rinse" mode. Check rotation.
- Good Luck !
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
GE 24 in. GSD5940 Built-in Dishwasher Logo
269 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
