Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Routers I would like to know if I can connect one router to another and increase my signal and connection to time PC's on my network?I'm currently using an WBR-1310 Wireless G Router.Please advise, Thank You,Grandfrend
  • grandfrend Dec 05, 2007
    Thank you DGolfer. Yes that answered my question and solved the promblem. In fact you answered the question I was going to ask.
    Thank's again, you are the Master!
    Grandfrend
    DGolfer, is there a Extender that you would recommend for me?
    Please advise,
    Grandfrend
    Scholar:
  • 79 Answers
You cannot increase your bandwidth, if that is your question.. but you can increase the signal strength and/or your radius of access (distance from the Access Point) by adding what we call 'Extenders'.
Bandwidth is determined by the type of Wireless Specs you are running.. G is the fastest 'certified' bandwidth at this time. although the new "N' will be available soon.. (it is in stores now, but not considered a 'standard' yet... The release date is not due until 2009..
Here is a good guide to the various speeds:
http://en.wikipedia.org/wiki/IEEE_802.11
Posted on Dec 04, 2007
  • William Pecht
    William Pecht Dec 05, 2007
    You are welcome, grandfrend, and a Merry Xmas to you and yours....
  • William Pecht
    Although I do not use Dlink, I would suggest you stay with that brand if want good compatibility..
    DWL-G710 Wireless Range Extender
    http://www.dlink.com/products/?pid=357
    Good Luck!
Losing network connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 19, 2012 | Toshiba Computers & Internet
Have Eee pc with windows7. wifi connection looses connection every few minutes.Network adaptor problem
Sep 11, 2012 | ASUS Eee PC 900HA Notebook
I keep getting a popup saking you're connected to more than one network, please close all but the primary network
Your issue is due to the you having to routers active and the PC is connecting to both.
You will have to disable one of the connection in the main router for this occurrence to stop.
check you PC 's wireless connection and disable connectivity also to the secondary router.
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router
Oct 04, 2010 | Linksys WRT160N Wireless Router
Wireless Network Connection constantly reading low/vlow/no signal
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Jan 04, 2010 | Computers & Internet
Connect my Lynksys WRT54G2 Router with my Belkin (F5D6231-4)
You can connect 2 routers to each other. But the IP address will be different for both the routers .
It will be better to keep different names for the wireless network.
If you keep the same name, then it doesn't mean that the signal strength will be good. Because both the routers will broadcast their own signals.
If you want to increase the signal strength then you can purchase a wireless range expander.
Click Here for more info about the networking
Nov 04, 2009 | D-Link Wireless Starter Combination Kit...
D link router signal is being read by computer but is not allowing internet access. Help!!
SO you are able to see the signal from the router to the computer but still not able to access the internet.
Is it connected to the network with the wired connection or with the wireles connection ?
Click Here to know more about routers and networking
Oct 25, 2009 | Computers & Internet
Can I boost signal strength?
You will need to get hold of a Belkin Wireless G Universal Range Extender relays the signals of your wireless network and extends its range model number F5D7132 from PC world or another online dealer.
You will still need the wireless router as the central connection point, using the booster your network now reaches further I have one at the top of the stairs with the Router downstairs to I can browser wirelessly in the loft conversion of my old house
Oct 11, 2009 | NetGear DG834G Wireless Router
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
Wireless networking problem
Access points receive the wireless signal and re transmit it again.
Once you enter the web interface of the access point, you would have to connect it to your wireless network. Once that is done, you should be able to connect to the same network , with a stronger signal , from your access point
Thanks Ranjit
Aug 19, 2009 | Cisco Aironet 1100 Wireless Access Point ...
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
