Question about Mitsubishi VS-50605 50" Rear Projection Television
Picture does not work anymore
I have had an issue of the picture going out intermittently, but coming back on after turning the TV off. Now, the picture will not come on at all, but I have full sound. Is this something that is worth fixing or should I say my goodbyes?
  • tzcaper Aug 11, 2008
    I have this same TV and sounds like I have the same problem. No picture but sound, when I go to turn the volume up it stays the same and when I try to change the input I dont even get the green letters at the top of the tv. I do get the green led light next to the power button though.
  • Mitsubishi Master
  • 8,617 Answers
Could be a deflection problem also could be a pip related failure. If you push menu when the pic is out do you have on screen display? This would rule out a deflection problem if on screen display works.
Posted on Feb 10, 2008
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
Intermittent problem of no picture
Archive Projection TV Repair Answered Questions QUESTION NO. P710-9: Sony KP-53XBR45 projection TV picture had severe intermittent vertical pincushion symptoms. Pincushion problem stopped and picture now ...
No thank you, Not interested in buying another TV at this time But the above solution should give ya some ideas in what to look for and could help ya and get your tv back on again.
Good Luck, Please dont for get to Vote.Thank you
Dec 14, 2007 | Samsung HLN5065W 50" Rear Projection...
Sharp LC 26sh20u picture problem
There are several capacitors on the main board and the power supply that can go bad with age. There are repair kits available that address this problem. Go to www.shopjimmy.com to see what's available. TV Parts DLP TV Lamps TV Repair ShopJimmy
Jan 14, 2014 | Televison & Video
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Horizontal line through the middle with sound. If you hit the side of the TV the picture will come back and then go away again.The TV is about 10 years old. Every now and then the picture will flash...
sounds like an intermittent problem. it could be a cold solder and it needs to be resolder it at the VERTICAL IC or transistor section , if your good with tools , you can do it yourself , otherwise take TV to a nearest repair shop, hope this helps , AJ
Jul 07, 2009 | JVC AV-27230 27" TV
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
Mitsubishi VS-50605 50" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
