Question about Motorola Mobility RAZR V3i Cellular Phone
No display My Phone suddenly went off while i was Talking. Now cant switched it On . No display . battery is New . and checked with another battery also .. guys suggest me any solution . my mail add is ankushdhar@gmail.com Thanks .. Ankush
  • ankushdhar Dec 05, 2007
    Sir the battery is new ... Chip connection is also Fine ...
    Now whats Display card ?
    Plss sugegst some realistic sollutions
Check if the handsets battery is new.
Also check the chip of the connection u r carring.
Check its displaycard too.
Posted on Dec 04, 2007
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
My Samsung D800 suddenly stopped working. I tried
the problem is not for your battery but the problem is with your hardware
Jan 18, 2010 | Samsung SGH-D800 Cellular Phone
My phone all of a sudden went dead and I cant turn it back on
this is a software fault . flash it & become ok
Aug 20, 2009 | Nokia 1661 Cell Phone
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
How can i solve the problem of low usage of battery packup?
Friend, since it appears that way eventhough the batt is new. As a mobile phone technician i diagnose base from my experience that the problem of your phone is not the battery but the power supply I.C. called CCONT. It is needed to be replaced or resolder especialy if it is shorted.You need mobile technicians to solve this problem. good luck
Apr 29, 2009 | Nokia N70 Cellular Phone
Philips 355 display
you must bargain your cp
Dec 19, 2007 | Philips 355 Cellular Phone
My display outside and inside isnt working for my motorola razr v3
bring it to a technician, and let him know what the new battery and charger did to your normally fine phone. They should be responsible for repairing your phone. No easy fix as described above. Let me know how it works.
Cynthia Charczenko
Nov 04, 2007 | Motorola Mobility RAZR V3
What a mistake
yo dude take out the chip and battery blow out the ohone with air put the battery in it again let it sit for an hour and turn it on again and it should work
Nov 29, 2006 | Motorola Mobility V220
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
