Question about Hitachi CP-X250 Multimedia Projector
Image has yellow tint even with nothing connected
On startup with nothing connected to the unit as well as all connectors (computer image, SVHS image), the image displayed is Yellow throughout.
Am I right in suspecting there is an internal problem or short between the board and the lamp with the blue signal?
  • 34 Answers
I am not a 100% sure, but that would be my first thought on what the problem is. I would call Hitachi support and go through troubleshooting with them to find out the cost of the repair.
Posted on Dec 05, 2007
How can I fix a synmaster b1630 monitor that has green tint on screen now?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 27, 2014 | Samsung SyncMaster Computers & Internet
Ineo +200 status p 6 and p 21
P-6 : Cyan imaging unit failure
P - 7:Magenta imaging failure
P -8 :Yellow imaging unit failure
P -9:Black imaging unit failure
Select Imaging Process adjustment - D Max Density and if the setting value is negative readjust.
Check the drive transmission portion of the imaging unit and correct as necessary,clean theIDC registration sensor windows if dirty,clean the contact of the imaging unit connector if dirty,check the high voltage connector for proper connection.If necessary change the image unit or the image transfer belt unit.
P -21 : Color shift test pattern failure.
Wipe clean the surface of the transfer belt with a soft cloth or change the image transfer belt unit if the transfer belt is damaged.
Feb 21, 2013 | Konica Minolta Office Equipment & Supplies
How do i connect it to my old sharp TV whic has a red yellow and white rca jack
Depending on how old it is, your probably not going to be able to. You need a SVHS connector on the TV set to connect the computer to it. There are some converters you can buy at Radio Shack that will convert "Composite (this is the Yellow Connector)" to SVHS, but your going to have to wrestle with the cost to do that. You may want to just put the money toward another TV new/used that has the SVHS connector already on the set.
Wish I had better news...
Jim
Dec 20, 2009 | Toshiba Satellite M45-S265 Notebook
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Ibook g3 av port needs possible replacement?
Your yellow tint issue can be from two different things. One, it can be a setting on the projector itself. Two, or can be the screen you're projecting your image onto. Your projection screen needs to be very white to get good results.
Jul 06, 2009 | Apple iBook G3 Mac Notebook
Magenta tint to the projected image
The Lens assembly requires service. The dust is inside the panels.remove the dust and that will work fine
Apr 19, 2007 | Toshiba TDP-MT500 Multimedia Projector
Yellow-green tint
I had the same problem and found out that it was the cable from the projector to the computer. HD D-sub 15-pin cable.
Dec 25, 2006 | Sony VPL CX10 Multimedia Projector
Hitachi CP-X250 Multimedia Projector Logo
487 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
doylesouders
Level 1 Expert
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
