Question about Canon imageCLASS MF8170C All-In-One Laser Printer
Alarm the machine is saying check paper size and when we change the paper size to letter it automatically resets back to legal and will not print
  • 56 Answers
Have you checked to make sure your paper guides in the paper tray are set correctly? If so then you might need to go into the printer menu and see what the paper size is selected for on that paticular tray!!
Posted on Dec 04, 2007
  • mrfireman180 Jan 25, 2011
    In order to reset your printer so the alarm will go off and clear all that you are printing all you have to do is
    Press <> or <> to select [REPORT STATUS], then press .
    If there is no job, [NO REPORT JOBS EXIST] is displayed.
    If there is only one report job, go to step 4.
    Press <> or <> to confirm the report.
    If you want to delete the report job, press .
    If you decide to delete the job, press <> for [YES].
    To cancel deleting the job, press <> for [NO]. Once the job is deleted, the job cannot be restored.
    Press to return to the standby display.
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
How do I get my hp 1320 printer to automatically print legal or letter size documents?
From my experience of commercial Dell and Ricoh office printers you have to specify what paper is in what tray and which one is the Default to print if no other instruction is given. When you want Legal, you have to change it just before you print.
Easy link to your manual
http://images10.newegg.com/User-Manual/User_Manual_28-414-324.pdf
HP Support page on the printer
HP LaserJet 1320 Printer User Guides
Jan 01, 2018 | HP Office Equipment & Supplies
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
Settings in HP Printer LJ 4100.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
Redued size of legal contracts on receiving fax sent to
HELLO! THE PROBLEM IS NOY ON YOUR END, THE MACHINE AT THE OTHER END HAS TO BE SET UO FOR LEGAL PAGES.SOME PEOPLE HAVE TRAY FOR LEGAL AND ONE FOR LETTER, THEN THE MACHINE WILL CHOOSE IT AUTOMATICLY. GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFax-4100e Fax
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
217 people viewed this question
old marine
old marine
