Question about Mintek MDP-1815 Portable DVD Player
On/Off Switch does not work.
How difficult is it to replace the on/off switch that does not work?
  • lojer99 Jan 08, 2008
    The plastic on/off switch broke off the unit. I need a new plastic switch. The unit still works but can't turn it on with a new replacement plastic switch. Please help!
  • 979 Answers
You will have to acquire a new front panel as that part is an assembly....accordianman
Posted on Feb 22, 2008
On/off switch not working
Most definitely! Toggle switches are usually very easy to replace. However if you're talking about the on/off switch for the car (ignition switch) yes, they can be replaced as well, but are usually a little more difficult and detailed. Hope this helps
May 09, 2016 | Cars & Trucks
I have a 1996 gmc Sonoma. Headlights will work sometimes.
Consider the dimmer switch on the steering wheel; the wires from it wouldn't affect the tail lights, but could possibly affect the headlights. Hopefully loose wires from the assy is the problem.. replacing the unit might be difficult. or expensive.
Jun 01, 2015 | 1996 GMC Sonoma
Jaguar s type 2001 driver window master control not working lights off,but windows work individually on each door
Replace or repair the bad/loose connection on the "Master" switch.
It could be severely difficult, if so take to a reputable Mechanic Shop.
Oct 15, 2012 | Cars & Trucks
1997 Chevrolet Lumina neither back up lights working after replacing fuse and both bulbs. Any Ideas?
There is a switch on the transmission with two wires on it. It is the reverse light switch. When the two wires are bridged together with the key on the reverse lights should work if the switch itself is defective. It is quite easy to replace, it just unscrews from the transmission if it is a stick shift, if it is an automatic transmission the switch I believe is part of the inhibitor switch and is more costly and difficult to replace.
Jun 29, 2011 | 1997 Chevrolet Lumina
Brake light not working on 2007 ultra classic foot pedal only
Sounds like you've got a bad front brake light switch. This little switch is inside the right handlebar switch housing. You can replace the switch by removing the throttle cables and taking the housing apart. Unless Harley has changed something, the switch is not difficult to change but the old wires have to be resoldered onto the new switch.
Good luck
Steve
Sep 05, 2010 | 2001 Harley Davidson FLHTCUI Electra Glide...
Our hunter fan won't work on high speed any longer, low and medium speed work fine, when clicked on high - it only goes at medium
Sounds like the variable speed switch may be worn out.
You should be able to purchase replacement switch at the local home depot- type store in the electrical supplies.
Trying to get an exact match to replace may be a bit difficult, but a similar 3 speed switch should work just fine.
Jul 18, 2010 | Hunter Ceiling Fan Control Switch
On/Off switch does not work. Saw turns on when plugged in and the switch does not turn the saw off.
its difficult but possible to repair those switches... best just o replace the switch
Dec 05, 2009 | Saws
My lights will not turn on sometimes with the switch i have to mess withe the dimer switch to get them to work and my blinkers dont work sometimes what could be the problem?
Unfortunatly it is in your dimmer switch. You will need to replace it. It is fairly difficult..but if u choose to try yourself i will try to walk u thru.:)
Sep 07, 2009 | 2000 Ford Focus
THE OVERDRIVE SWITCH ON MY 1997 F-250 IS BROKEN OFF AND I KEEP HAVING TO TOUCH THE EXPOSED WIRES TOGETHER TO GET THE OVERDRIVE TO FUNCTION. HOW DO I REPLACE THE SWITCH, IT LOOKS DIFFICULT?
is the switch on the selector you must replace the whole rod if so you`ll need special tool to do so is not so difficult but you will need some kind of guild to do so
Jun 29, 2009 | Ford F-250 Cars & Trucks
1994 Camry ..Hi beam and DRL's are intermittently working
It is in the Switch. It is tough to replace and the Dealership is the Only Place that you can get this Switch Also. Please Rate My Response! Thanks!
Jan 31, 2009 | 1994 Toyota Camry
Mintek MDP-1815 Portable DVD Player Logo
27 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
