Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer makes noise but will not print
  • Anonymous Dec 06, 2007
    have got an hp p0sc 2355 all in one printer and all of a sudden it wont print I have recently changed ink cartiridges but nothing happens it says it's printing on the little screen but does nothing
Lexmark c772 when printing it make load Laud noise
Please power off the printer. Remove all the toner cartridges. And then put them back in. Make sure you install the toner cartridges properly. After that power on the printer. Try printing again.
Jul 20, 2012 | Lexmark C772dn Laser Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
89 people viewed this question
Ben Johnson
